Previous in Forum: Cable Gland in IIC Area for Exn Motor   Next in Forum: Sanyo Air Conditioners 36,000 BTU - Not Restarting
Current and Voltage Transducer Vs Current and Voltage Transformer
09/05/2011 12:47 AM
what is the difference between Current Transducer and Current Transformer...?
What is the difference between Voltage transducer and Potential transformer..?
Re: Current Transducer Vs Current Transformer
09/05/2011 12:51 AM
Google it.
Good Answers: 244
Re: Current and Voltage Transducer Vs Current and Voltage Transformer
09/05/2011 12:03 PM
Transducer is a generic term used for a device which transforms a signal (such as current voltage, temperature etc) to a corresponding (ratio) signal such as current or voltage, while the current (or voltage) transformer is a device which transforms a current (or voltage) signal to a corresponding current (or voltage) signal. So, current (or voltage) transformer is a type of transducer.
So, all current (or voltage) transformers are the current (or voltage) transducers but all current (or voltage) transducers are not the current (or voltage) transformers.
- MS
09/05/2011 11:33 PM
Transducer needs excitation like 50Vdc and when a voltage(0-400V) from a VT or a current(0-5A) from a CT is applied, it will give a signal(4-20mA) which when given to a corresponding current/voltage transducer in another location will indicate the actual current or voltage at the site.
pnaban
Register to Reply 3 comments
lyn (1); msamad (1); pnaban (1)
