Previous in Forum: Compressive Strength of Laminate Composite   Next in Forum: Propane Chiller
9 comments
FRP Lining Removal Methods
09/05/2011 6:44 AM
What is the best method for removal FRP lined pressure vessel ? grinding of FRP lined pressure vessel will increase the labour hours for that Job.
Any other alternatives for removal of this type lining .
Thanks in advance for the reply
Re: FRP lining
09/05/2011 6:53 AM
Removing the vessel, or removing of the lining from the vessel? Please clarify.
Re: FRP lining
09/05/2011 7:03 AM
i meant pressure vessel, for corrosion internal lining should be done ( depending upon the media used in the pressure vessel ), some clients prefers FRP lining while the others prefer Rubber lining.
Good Answers: 137
Re: FRP lining
09/05/2011 7:31 AM
But I thought you were asking about removal of the (FRP) lining. What has client's preference to do with it?
Codey
Re: FRP lining
09/05/2011 7:43 AM
Yep. Please eliminate the confusion in the question.
Re: FRP lining
09/05/2011 7:53 AM
my question is , the best method for removing the FRP lined pressure vessel
Re: FRP lining
09/05/2011 8:10 AM
  • What size is it?
  • How heavy is it?
  • Does it have any lifting lugs?
  • Is there scope to get a crane over it or does it need to be jacked and wheeled out on skates? Is there a doorway big enough?
If these sorts of thing could go in the original thread posting, next time, responses from the forum will be much faster.
Re: FRP lining
09/05/2011 8:51 AM
It was a general question ( removal of internal FRP lining in a pressure vessel ). There should be a manway in the pressure vessel.
  • size of the pressure vessel: 3.2 m dia x 4.8 m dia
  • yes it has lifting lugs
  • the doorway is big enough to enter a person
Re: FRP lining
09/05/2011 9:04 AM
  • Why is the lining needing to be removed?
  • Would it make more sense to replace the vessel with a non-lined version instead, and cascade the lined vessel elsewhere with its inspection certification dosumentation intact? What is the secondhand value of the cascaded vessel on the open market?
  • Would the method of removal of the lining affect the pressure rating and certification of the vessel once modified?
Re: FRP Lining Removal Methods
09/05/2011 6:16 PM
If the client wants rubber lining, why not leave the FRP lining in place and just add the rubber lining?
Register to Reply 9 comments
Codemaster (1); PWSlack (4); shafeeque (3); Tornado (1)
