Previous in Forum: PID tunning   Next in Forum: Valve Sizing
Speed Measuring Device For This Kind of Shaft
09/10/2011 7:09 AM
There is a vertical shaft (kelly) that rotates(vertical axis) and moves up and down in vertical direction. Currently we are using a speed probe that generates pulse after sensing the rotating bolt like structures on its top. as the kelly moves up and down very frequently the cable of the speed probe always gets damaged and hence replaced everytime it gets damaged.
What I want to know is whether i can measure the speed of this kind of shaft using some other technology? please suggest
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
Re: Speed Measuring Device For This Kind of Shaft
09/10/2011 9:49 AM
One solution is to mount the speed probe on a bracket that moves up and down with the shaft, if that is possible.
Another solution is to electrically derive the speed from the motor turning the shaft. For example, if the shaft is turned by an induction motor powered by a VFD, you may approximate shaft speed based on the output frequency of the VFD.
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
Good Answers: 151
09/10/2011 11:38 AM
Would it be possible to use a ball spline in a section of the shaft? This will allow the ball cage to rotate in a stationary position with the shaft able to move freely in the vertical direction.
Good Answers: 150
09/10/2011 9:21 PM
paint a white line all along the kelly shaft and use something like this in a fixed position.
http://www.shopextech.com/p7258/extech_461700.php
Who is John Galt?
09/10/2011 11:33 PM
That's what I was thinking--a painted line of some contrasting color extending some length along the shaft so that the sensor can remain stationary while the shaft rotates and moves up and down. A magnetic strip would also work--depends on what your sensor can read.
Lehman57
09/10/2011 11:40 PM
If this is driven by a kelly bushing from a rotary table you can mount the probe (pepperl fuchs induction coil?) underneath the deck in an area where you do not get any vertical movement.
The drive spline on the table motor will have similar "targets" to what you are aiming at on the hook assembly.
It gets pretty dirty & nasty down there with drilling mud and the like so any sort of optical device would have an issue.
Stress? That's what you get when you do something interesting and worthwhile; if you can't handle it get out of the gene pool.
09/11/2011 6:05 AM
The overhead drive does not have,RPM,to the
Golograph? Or is it rotary table driven?
Why cant the counter ride the drive? Then
the up and down would not matter.
and these truthes shall be held self evident that all men are created equall
Register to Reply 6 comments
gringogreg (1); Lehman57 (1); Philo (1); Rorschach (1); tonykuphaldt (1); UsernameJUDGE (1)
