Previous in Forum: Adding 6,000lbs to a Concrete Floor   Next in Forum: Pile Foundation
13 comments
Necessity The Reason of Inventions.
09/10/2011 10:05 AM
Vacuum denotes a field magnetically unfilled wth space and vacant of mediumistic material substances. The Energy of the Vacuum is nothing but the underlying background energy which exists within space, even when the space is devoid of mediumistic material substances of nature in accordance with unconditional norms of The Substantiality referred to as Animism according to the virtuous principle of The Conceptive-Science prior to The Sciences, in form of The Natural Forces of Creation. The Concept of Vacuum Energy has been deduced from the concept scientific of virtual particles, which is derived from the Energy-Time Uncertainty Principle. The animism or the animistic radiation of the Elementals whch denotes the termination of the direct Light Radiation whose source of orignation is The Divinity of The Creator, out of the Omniscience. A Bose-Einstein Condensate which is the precipitation that substantially manifest within Subsequent Creation of all heavy gross material substances, is primarily a state of matter of Bosons, which are confined in an external potential and cooled-off to temperature very near to absolute zero (0 Kelvn or -273.15degrees celsius) under such supercooled entropy, a large fraction of the atoms collapse into the lowest quantum state of the external potential, at which point, quantum effects became obvously apparent on a macroscopic scale. The condensation of a precipitation trickles and submerge to a peculiar level of attainable balanced equilibrium of stability. Fermi"s golden rule is a manner of calculating the transition rate (probability of transition per unit-time) from one energy "eigenstate" (energy state) of a quantum entropy into a continuum of energy eigenstates, due to perturbation. Creation is a unique continuity of energy from the source, The Divine Omniscience through The Con-Science and finally to the physical visible Sciences of the subsequent Creation of the earthly surface plane. The effects of the Elementals of The Ring of Animism are realized and felt within the gross earthly world of material substances. These energy are cooperatively dispensed in form of Fire, Water, Air and Earthly Physical Substances. The Heisenberg uncertainty principle, states that by precise in-equalities, certain pairs of physical properties, such as Postion and Momentum, cannot simultaneously be known to arbitrarily high precision. This means that, the more precisely one property is measured, the less precisely, the other property can be measured. This is determined by the Constant of Planck which is a physical constant, reflecting the sizes of quanta in quantum mechanics. It is the proportional constant, between the energy (E) of a photon and the frequency of it"s associated electromagnetic wave (V). This relationship between energy and frequency is called The Planck-Einmstein equation: Divine Light: N x Ne x fi x fl x fc x L.
Pathfinder Tags: civilengineering nventions
Re: Necessity The Reason of Inventions.
09/10/2011 10:16 AM
Huh?
And this is related to what?
Good Answers: 67
09/10/2011 11:39 AM
For such things, when I was student, one of my teacher used to say- "an illusion created by God".
Could have been made simple by breaking sentences and para to smaller ones. The reason for posting it on "civil engineering" may be best known to OP, how it is related. I could see so many things other than civil engineering, for example- physics, quantum mechanics, space sciences etc. Sections like 'General', 'Chemical-material-science', 'New-technologies & research' etc might have been more opt.
Good Answers: 101
09/10/2011 12:05 PM
Oh boy, here we go again. After all this time I thought we heard the last of this guy's ravings.
Good Answers: 183
09/10/2011 1:06 PM
Great ! Since Kastrasky (In fact I do not remember the name of the genius but it was something of this kind) nobody came to such a level !
I found - driven by curiosity - this wonderful answer of the OP: " You are the arrogant types, because it is up to you to determine what people ought to write. You need advance education to comprehend." Says every thing about what we have to expect !
09/10/2011 1:23 PM
It seems a little early(or late) for April fool.
Mr.Ron from South Ms.
Good Answers: 151
09/10/2011 1:34 PM
This is exactly what happens when you combine a small amount of quantum mechanics with a large amount of marijuana.
09/10/2011 3:02 PM
It also applies to people with tiny grasps of applied reality and big delusional egos.
09/10/2011 3:01 PM
The latest news directly from Lalaland!
Hobbies - Fishing -
09/10/2011 11:24 PM
N x Ne x fi x fl x fc x L =?
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.” -Mark Twain
Good Answers: 164
09/14/2011 6:46 AM
Well, right from vedic times it is well known. Here it is in original.
There were some nuts in India in Vedic times too. Come to think of it, i am not that different either
09/14/2011 11:53 AM
Clap! Snap! the black crack!
Grip, grab! Pinch, nab!
And down down to Goblin-town
You go, my lad!
Take your meds!
09/19/2011 9:51 AM
Try switching to decaf.
09/19/2011 10:57 PM
For competing with others in the field of business and technology(USA Vs USSR) also inventions are not done not only for necessity
pnaban
Register to Reply 13 comments
DVader1000 (1); gringogreg (1); kvsridhar (1); lighthasmass (1); lyn (1); nick name (1); pnaban (1); pritam (1); PWSlack (1); ronseto (1); russ123 (1); tcmtech (2)
