Previous in Forum: PCB Cards in ABB VFD Drive Panel   Next in Forum: Drying Out an Alternator
Relay Setting of 22 MW Alternator
09/11/2011 8:55 AM
can anybody explain the relay setiings of 22 Mw Turbo alternator.Details og Alternator
TYPETC210SYSTEMBRUSHLESS EXCITATIONMODELTEW18E
O/P KVA27500OUTPUT144 kWOUTPUT8 KVA
PF.0.8 lagVOLTAGE288 voltsSPEED1500 rpm
VOLTAGE11000 VCURRENT500 apmsFREQUENCY50 Hz
ARM.CURRENT1443.8 AEX. VOLTAGE95 volts VOLTAGE225/130 volts
FREQUENCY50 HZEX. CURRENT20 ampsCURRENT20.5 apms
SPEED1500 rpmENCLOSUREIP 54EX. VOLTAGE53 volts
NO.OF POLES4COOLINGIC 9AIW7EX. CURRENT7.0 amps
NO.OF PHASES3INSULATIONCLASS "F"RULEJIS JEC
INSUL.CLASSSTANDERDIS-4722POLING No. OF PHASE3
STATORCLASS `F`MACHINE No2K40660-01
ROTORCLASS `F`
EXCITORCLASS `F`
TEMP.RISECLASS `B`LIMIT
ENCLOUSERIP 54
COOLING SYSTEMIC9A I W7
BEARINGSSLEEVE BEARINGS
COOLANT TEMP.Bitmap32 C
GRS/OILISO VG 46
QTY(GM/I pm)45(DE/NDE)
EXC.VOLTAGE274V
EXC.CURRENT476A
M/C.NO.2K40660-01
Pathfinder Tags: relay setting
Good Answers: 445
Re: Relay Setting of 22 MW Alternator.
09/11/2011 3:41 PM
There are many knowledgeable people here who can, but we would also need to know the environment that it is going to be installed in, parameters of the system that it will be attached to, etc., etc. Your best bet is to go back to TDPS, the contractor that supplied the system or the engineering firm that did the specifications. If you want to learn about protective relaying in general there are plenty of good sites on Google.
Good Answers: 19
09/11/2011 10:44 PM
Relay settings for these type of captive power plants is being done on professional basis.one has to study the detailed SLD and other aspects.
Ramesh,Freelance Electrical/automation Consultant
Good Answers: 170
09/12/2011 7:45 AM
What are the relays you are having to protect this alternator? Make & Type would help us to suggest better.
Register to Reply 3 comments
electricalexpert65 (1); RAMConsult (1); ramvinod (1)
