Previous in Forum: Automation of Job Sorting Machine   Next in Forum: DIY Large-Scale Ultrasonic Parts Cleaner
RCBO'S
09/13/2011 9:41 AM
I am wondering if I "left the switch cover off" on a 240 v single switched fused spur, the wires although live are properly terminated, the circuit is protected by an rcbo 30milliamp rating, now I know, and you know that you cannot touch the terminals with fingers, Now if someone inserted a piece of metal onto the live terminal, he or she would make a circuit to earth and in 40 milliseconds the breaker would trip, would this cause an injury or burn? I know that the shock would not be fatal.
Re: RCBO'S
09/13/2011 9:46 AM
Colinp, how do you know the shock would not be fatal?
Re: RCBO'S
09/13/2011 10:06 AM
Because RCD's are intended to operate within 25-40 milliseconds which is before electric shock can drive the heart into ventricular fibrillation, which is the most common cause of death through electric shock
Re: RCBO'S
09/13/2011 10:08 AM
So is it wise to rely on them? Can one be 100.00% sure that such a shock is survivable?
Good Answers: 181
Re: RCBO'S
09/17/2011 2:26 AM
Try it, if you survive let us know your findings.
India - Member - New Member
Good Answers: 164
Re: RCBO'S
09/13/2011 11:27 AM
If someone was foolish enough to insert a metal piece into what is obviously an electrical equipment, he deserves whatever happens to him. Most likely he is a thief looking to take away copper and other saleable things.
Did you leave any fingerprints ? If not, have a drink and go to sleep....
Colinp (1); Doorman (1); kvsridhar (1); PWSlack (1); TonyS (1)
