Previous in Forum: Velocity Criteria For Caustic Solution & Carbon Disulfide   Next in Forum: Bonding Kevlar Material to Aluminum
11 comments
Which is the Best at Supporting?
09/14/2011 8:51 AM
dear friends ??
which is the best at supporting ... Galvanized steel or stainless steel 316 ?
Re: Which is the Best at Supporting?
09/14/2011 9:11 AM
Hi
I found that a member asked same question in this forum some months ago.
Pls use search box to find this questions with comments
09/14/2011 9:18 AM
Thank you ,, but which key word i shall use ?
09/14/2011 10:01 AM
Material Properties
From engineering tool box
Good Answers: 137
09/15/2011 6:15 AM
Unless there's a good reason to use stainless (eg corrosive environment) why would you consider it? Galvanized steel and stainless steel are similar strength and galvanized is cheaper. Also easier to work, wrt welding, thread spalling etc.
Codey
09/15/2011 7:38 PM
Stainless is shiny.
09/16/2011 8:59 AM
Nononononononono! Don't weld galvanised steel! The fumes are highly toxic!
Cold-dip galvanise after welding and clean-up? No problem.
Good Answers: 137
09/16/2011 10:53 AM
OK, I always thought the zinc burnt off and you could weld as normal, but I'm no expert on welding.
Codey
09/16/2011 10:59 AM
I. CHEMICAL AGENTS
ZINC
Zinc is used in large quantities in the manufacture of brass, galvanized metals, and various other alloys. Inhalation of zinc oxide fumes can occur when welding or cutting on zinc-coated metals. Exposure to these fumes is known to cause metal fume fever. Symptoms of metal fume fever are very similar to those of common influenza. They include fever (rarely exceeding 102o F), chills, nausea, dryness of the throat, cough, fatigue, and general weakness and aching of the head and body. The victim may sweat profusely for a few hours, after which the body temperature begins to return to normal. The symptoms of metal fume fever have rarely, if ever, lasted beyond 24 hours. The subject can then appear to be more susceptible to the onset of this condition on Mondays or on weekdays following a holiday than they are on other days.
"It's not the dress that makes you look fat. It's the fat that makes you look fat." - Al Bundy
Good Answers: 137
09/16/2011 12:26 PM
Thanks, the implication of that is the welding still works OK. It wouldn't surprise me if welding of galv steel goes on. If it's outdoors (structural steel likely to be) keep upwind of the workpiece. If indoors, use an ordinary fan to disperse fumes. Keep other workers out of the way, of course.
Codey
09/21/2011 3:37 AM
If you want to get more materials that related to this topic, you can visit:
http://howtointerview.biz/civil-engineering-interview-questions
Best regards.
09/21/2011 3:47 AM
Thank you :)
Register to Reply 11 comments
Codemaster (3); hambim336 (2); lyn (2); PWSlack (1); stylee_eng (2); thall (1)
