Previous in Forum: Pressure & Vacuum   Next in Forum: Contact Bouncing in Starter Motor Solenoid
Hydraulic Efficiency
09/16/2011 12:46 AM
I'm considering building an off-road vechicle using an internal combution engine to drive a hydraulic pump. The pump will drive two or four hydraulic motors as transaxles. How much power loss can I expect if I use steel tubing to deliver high pressure fluid to the motors compared to a mechanical setup?
Good Answers: 101
Re: hydraulic efficiency
09/16/2011 1:46 AM
You are asking a hugely vague question, and aren't really comparing apples to oranges.
but here goes...
What kind of "mechanical setup" are you referring to? My mind goes to a standard trans-axle/transmission/transfer case/differential setup. Which in that case you are looking at roughly 15-20% efficiency from engine to road, depending wildly on the "setup".
If you went hydraulic, with a diesel engine running steady in it's power-band "sweet-spot" lets say at 45% efficiency running a bent axis piston pump at 90% efficiency, turning bent axis piston motors also running at 90% efficiency, with more losses added in for bends/fittings/valves/heat exchangers etc. lets throw out another 15% loss for the "extras" etc etc etc. after doing the "napkin" math, I come up with maybe somewhere around 30% efficiency.
Now...
Keep in mind, I may have tossed a few back, and my rhetoric may be a little off, but there it is.
Cheers!
Good Answers: 137
09/16/2011 8:05 AM
Not sure that helps the OP much. "......looking at roughly 15-20% efficiency..." presumably means from power in fuel to power at wheels. Seems a bit low, even with a petrol engine at say 30% efficiency. But OP asked about difference between hydraulic and mechanical transmission. It confuses things to then consider hydraulic transmission using a diesel at 45%. The higher engine efficiency could account for most of the change from 15 - 20% to 30%.
My best guess, for transmission only is - mechanical 85-90%, hydraulic 75-85% but somebody out there might have more accurate data.
Codey
09/16/2011 5:33 PM
yes, you're correct. i meant a conventional 4x4 vs a hyaulic system using the same engine. i was considering power loss from u-joints, gears, ect.
Re: Hydraulic Efficency
09/16/2011 9:11 AM
By far the most efficient transmission system on the planet is the dérailleur speed-change mechanism fitted typically to the modern safety bicycle.
Good Answers: 137
09/16/2011 10:57 AM
But you don't see them on 4x4 off-roaders too often
(BTW appreciate the acute accent. A pedant after my own heart!)
Anonymous Poster (1); Codemaster (2); PWSlack (1); RVZ717 (1)
