Previous in Forum: How I Minimizes the Leakage Voltage   Next in Forum: Five-second Biomass Power Generation will Exceed PV
Solar Power
09/18/2011 7:00 PM
I am looking for information on Black solar panels.
Re: Solar power
09/18/2011 7:05 PM
  1. Black solar panels and global warmingwww.genuineideas.com/ArticlesIndex/blackAndWhite.htm - CachedJun 14, 2007 - If, instead of a black solar panel absorbing light and producing electricity, you simply painted that square meter white, it would reflect back into ...
  2. Shopping results for Black solar panels
    Evergreen Solar ES-A-210-FA3 210 Watt Photovoltaic Solar Panel - Black
    $559 - 3 storesPowerFilm F15-600 Solar Charger Foldable 10W Black 23.7x21
    $103 - 126 storesBrunton F-RESTORE-BK Restore 2 SlrPanel/2200mAh Bat BK
    $61 - 58 stores
  3. Trina TSM-230PA05 230-watt solar panel, Black Frame and Panelwww.wholesalesolar.com/.../TrinaTSM-230PA05_black.html - CachedWholesale Solar is now offering the Trina Solar PA05 230-watt solar panel in black. The PA05 black, 230-watt solar panel combines Trina Solar's high-efficiency ...
  4. New Black Silicon Solar Cells are Cheap and Absorb More Sun ...inhabitat.com/new-black-silicon-solar-cells-are-cheap-and-absorb-m... - CachedSep 3, 2010 - Researchers have found a way to make black solar cells. They're cheap, easy to make and ultra absorbent.
  5. Black Silicon Makes Solar Cells Cheaper - Technology Reviewwww.technologyreview.com/energy/24968/ - CachedApr 2, 2010 - A one-step process creates a highly antireflective layer for photovoltaics.
Re: Solar power
09/19/2011 10:55 AM
I have found these panels oversees and the difference is that they run off the ultra violet rays of the sun. I am trying to see if there is any other information such as has any one in the US tried them or seen any data on these in the US. I am an engineer out of MIT and have been out of the loop for a lot of years. If you have constructive information that will be great but if others want to be condescending I will step off this program.
Re: Solar power
09/18/2011 7:12 PM
It seems that someone else is doing the actual looking....
Re: Solar power
09/18/2011 7:15 PM
It's what happens when you're bored. It may not help anyway. I don't review this stuff before I post it for slackers.
Re: Solar Power
09/18/2011 9:01 PM
Me too. Have you found any yet?
Anonymous Poster (1); blklknt (1); lyn (2); Tornado (1)
