Previous in Forum: Return oil color changed   Next in Forum: Hydraulic actuator
valves
04/21/2007 11:29 PM
Dear sir
please which valve is better for isolating gate valve or butter fly valve in HVAC system .
Thank you
United States - Member - USA Engineering Fields - Control Engineering - Never enough money
Re: valves
04/22/2007 2:31 PM
Depending on what is being isolated and what level of quality craftmamship you want will determine the valve type. What are you isolating? Is this a home system?
Good Answers: 19
Re: valves
04/22/2007 3:22 PM
In HVAC application for Isolating, you have to use 2 (two) Valves in series.
1st a Gate Valve & then a Globe Valve.
Re: valves
04/22/2007 3:44 PM
Heating, Ventilation, Air Conditioning (HVAC) There are many types of systems each with different needs and requirements which are also effected by the application (residential vs. industrial) and local building codes (if any exist, depends were you are in the world). If the HVAC system is a swamp cooler like the one my grandmother had then a gate valve to isolate the tap water is all that is needed but then again my grandmothers swamp cooler was from the 1940's.
Jawdat please post a little more information about your system and someone will get you the correct information on valves you are looking for.
Re: valves
04/23/2007 2:25 AM
How do you define your purpose, 'isolation'.
If your purpose is to, 'quickly isolate (quoter turn) but 100% leak-tight at high pressure is not rewired' then 'butterfly' could be your choice.
If 'Leak-tight' is your paramount, then 'gate valve' is your best bet.
For beginners there are few downloads (some are free) at: www.yesyen.com. A game on valve shows the internal constructions which could explain the above discussion.
Re: valves
04/23/2007 9:41 AM
Sorry for the spelling mistake, it should be:
If your purpose is to, 'quickly isolate (quarter turn) but 100% leak-tight at high pressure is not rewired' then 'butterfly' could be your choice.
Good Answers: 114
Re: valves
04/23/2007 10:08 AM
It also depends on the flow rate required @ small openings
Ballvalves are good for isolation
Gates [needle] for control
RW [resilient wedge] can be a good compromise between the 2
Re: valves
07/16/2007 1:52 AM
could you please tell me what HVAC system is
Register to Reply 7 comments
Anonymous Poster (1); ducon (1); Garthh (1); Richard L (2); yesyen (2)
