Previous in Forum: Simple Measurement of a Small Capacitance   Next in Forum: Creep of 304L
8 comments
Glider
09/20/2011 11:48 AM
glider dimensions 98*98*33 (all are in centimeters )
material plastic or fibre
Can it be launched/projected with a catapult to 20 centimeter range ..
This is not a assignment question for sure but want to know if above situation is possible
Re: glider
09/20/2011 1:05 PM
Check your numbers. Even a glider made of lead could go 20 centimeters.
Re: glider
09/20/2011 2:23 PM
Agreed. The listed distance is 20% of the fuselage length. You should be able to scoot it that far.
Re: glider
09/20/2011 9:42 PM
sorry it is 20 metres range ..... by mistake i typed it in centimetres
Re: glider
09/20/2011 9:41 PM
Re: glider
09/20/2011 4:58 PM
Multiple choice:
a) 20cm
b) 2m
c) 20m
d) 200m
e) 2km
f) 20km
My bet: d) or e)
Re: glider
09/20/2011 9:47 PM
sorry what i mean is actually 20 metres ... not centimetres..
how much big catapult is needed for launching above mentioned glider up to 20 metres ?
i think rubber catapult cannot be used for this glider launch ??
Re: glider
09/21/2011 9:45 AM
harsha, can you help us out a little bit?
Is it made of lead as speculated by Usbport in question #1, or is it more like this:
What sort of answer are you looking for? Modulus of elasticity, length and extension load of a rubber band (together with the launch inclination angle)? The design and specification for a steam catapult? Something in between those two?
What question is your instructor asking? That information may speed things up.
Re: glider
09/21/2011 2:28 PM
i actually want to know how a 98*98*33 cm glider of plastic or fibre material ( weight optional ) can be projected to a distance of 20 metre by use of catapult ??? is it possible practically ... if so what type of elastic band and what length needed??
Register to Reply 8 comments
Doorman (2); harsha_iit (4); Tornado (1); Usbport (1)
