Previous in Forum: Aluminium with Iodine   Next in Forum: Latex Paint Overspray
Chemical to Stop Reaction
09/20/2011 11:08 PM
I have DM plant & we regularly do re-genration at that time hcl & naoh is mix in ETP pit at that this both create salt.I want to know is there any chemical which stop rection between this chemical?
Pathfinder Tags: yatin
Re: yatin
09/21/2011 4:05 AM
DM - demineralisation plant?
hcl - hydrochloric acid?
naoh - sodium hydroxide?
ETP - effluent transfer pit?
If so then no, there isn't any need to stop this reaction.
Good Answers: 101
Re: Chemical to Stop Reaction
09/21/2011 7:39 AM
No. Then again, why do you want to stop the reaction?
Good Answers: 137
09/21/2011 11:38 AM
If you put both streams in the ETP there's no way to stop them reacting. These are waste streams from regen of the resin, containing excess acid and caustic. Usually it's better to mix them and let them neutralise each other, as this reduces the quantity of chemical needed to bring the pH close to 7 for discharge. If you have a use for what's left of the acid and caustic you could keep the streams separate, but they will contain other salts from the regen.
Codey
09/22/2011 6:24 AM
Well said. The more neutral the effluent, the better.
Register to Reply 4 comments
Codemaster (1); DVader1000 (1); PWSlack (2)
