Previous in Forum: Electric Heater Tubesheet-Design   Next in Forum: Why Was the Hydrostatic Test of Pressure Vessel Reduced From 1.5MAWP to 1.3MAWP?
Minimum Temperature of Upstream Piping Blowdown Utility HYSYS
09/22/2011 3:47 PM
Dear all,
Now I am working on the project which involves blow down calculation using HYSYS utility.
We need to blow down a small inventory (piping spool with volume of 0.3 m. cub) and concerned about the minimum temperature upstream of the restriction orifice because the design temperature of upstream piping is only -20°C. HYSYS provides us with two temperatures - vessel fluid (-26C) and inner wall temperature (-12C).
Could you please advise which of these temperatures do I need to use as a basis to protect upstream piping?
Thanks in advance.
Re: Minimum Temperature of Upstream Piping Blowdown Utility HYSYS
09/22/2011 4:48 PM
Is the vessel upstream, or downstream, of the orifice? What is the fluid and what are the upstream/downstream pressures?
09/23/2011 6:01 AM
Vessel (actually piping spool which needs to be blowdown) is upstream of the orifice.
Presures are 130 barg upstream and atmospheric downstream of the Restriction Orifice.
Thanks.
Register to Reply 2 comments
