Previous in Forum: Difference Betn Line Current and Phase Current   Next in Forum: On/Off Operation Times of Breakers
Negative Tolerance
09/23/2011 2:31 AM
What is meant by Negative Tolerance,
i heared this word in transformers.
what is the effect of tolerance.
Good Answers: 15
Re: Negative Tolerance
09/23/2011 4:39 AM
we shall try to teach you to fish . . .
follow the process . . .
power ON your PC . . .
allow time for the OS to load . . .
open a browser window . . .
TYPE either www.bing.com or www.google.com in the location bar (white strip on top into which one types) . . .
wait for google .com to load . . .
TYPE keywords like - negative tolerance transformer - with spaces between words into a search field . . .
HIT the enter key . . .
look at the results that load on your screen . . .
select links and go to the pages using appropriate mouse commands . . .
search again with different key words . . .
QED = quite easily done . . .
India - Member - Proud to be INDIAN Engineering Fields - Power Engineering - New Member
09/23/2011 4:47 AM
Rather than struggling to type this much, you could write the answer for his question!
you need to go, to get something
09/23/2011 4:52 AM
"His"? Does the forum know that the original poster is male?
09/23/2011 5:03 AM
Good question The forum does not knows but not me The original poster is from India, and that name is called for boys only. That is why i mentioned as "His", since i am also an INDIAN...
Clear???
United States - Member - New Member Engineering Fields - Biomedical Engineering - Biology, the most elegant Engineering Popular Science - Biology - New Member
09/23/2011 8:15 AM
Was that really necessary? This was a good question and exactly what CR4 is here for. The original poster does know how to fish and was fishing in the right spot because he did ultimately get his answer thanks to pritham. Google isn't the only place to go fishing.
Good Answers: 67
09/23/2011 4:54 AM
You can very well google it. Normally dimensional tolerance is specified on 'plus' as well as 'minus', for example 500+/-0.5 mm, which means dimension in the range between 499.5 mm and 500.5 mm is acceptable. But when it can vary on negative side only, it is called negative tolerance. For ex. 500-0.8 mm means in no case it shall be more than 500 mm (if it is more it may pose serious problem while inserting or fixing it).
09/23/2011 11:01 PM
Tolerance is allowed on performance figures of any equipment by standards.For example if the efficieny commited is 95% it can be +- certain % as given by standards.In cases where no negative tolerance is specified it means the minimum value of95% to be maintained between declared and measured valuethough upward value is permissible.This is used motly in tenders where evaluation is done on savings that accrue due to energy savings over a pre determined period.
Register to Reply 7 comments
Irving (1); nesubra (1); pritam (1); PWSlack (1); sharath4 (2); soebfatehi (1)
