Previous in Forum: Bulk (Remote Tank) Connections   Next in Forum: Life of RC Filter capacitor
Photovoltaic (Distributed Generation)
09/23/2011 11:38 AM
Hi everyone..
about this distributed generation i just wondering how to make voltage stability on photovoltaic with instability of radiance...
would be even better if given references relating to this....
i hope u'r willing to help., thanx n regards
Pathfinder Tags: photovoltaic
Re: Photovoltaic (Distributed Generation)
09/24/2011 12:46 AM
You might search on "voltage regulator" or "charge controller".
09/24/2011 2:05 AM
thanx for your response my friend...
09/24/2011 1:47 AM
can't give a reference. it's my unstanding that capacitors can store power until needed.
09/24/2011 2:55 AM
Not in the time frames required here. In this instance batteries are almost certainly required. Supercaps would maybe take you farther down the road, but "they ain't there yet".
09/24/2011 2:58 AM
I went to a nice lecture that talked about a 10 Megawatt solar farm that was instrumented by General Electric. The actual technology was not talked about very much, but it is inverter based and more like double conversion. One inverter creates the DC (or is it +-? Don't know) and the other synchonizes and creates the sine waveform.
With this technology, it is possible for the array to provide current at zero volts or put another way, provide local power factor correction.
You want a high voltage DC buss and you probably do that near each group of arrays.
Anonymous Poster (1); doni_petrucci (1); KeepItSimpleStupid (1); Mikerho (1); Tornado (1)
