Previous in Forum: Could Neutrinos be Tachyons?   Next in Forum: Neutral Problem
20 comments
Floor Plate Source?
09/24/2011 10:06 PM
I would like to find a source for floor plate with a raised pattern of squares on it. Similar to diamond plate / tread plate / 4-way plate / etc, except with raised squares. I thought Ryerson or McMaster-Carr would have it, but can't find it. I would also like to know a generic name to make searching easier. Thanks.
Lehman57
Re: Floor plate source?
09/24/2011 10:19 PM
I tried "textured steel plate" and got this (among others). Ignoring the pictures to the right, scan down to the third one on the left, sometimes described as "checker plate". I'm not sure it's what you have in mind.
09/25/2011 6:44 PM
Nope, didn't see what I'm looking for. Thanks.
Lehman57
09/24/2011 10:40 PM
09/25/2011 6:25 AM
It's in the former USSR. The shipping is going to be a killer.
09/25/2011 6:37 AM
Always with the negative waves, Moriarty ... Why don't you say something righteous and hopeful for a change?
09/25/2011 8:15 AM
Like this?
I didn't cancel your GA, I think you're already pissing off someone this morning though.
09/25/2011 10:38 AM
Me? It's a tough job, but somebody's got to do it.
09/25/2011 6:50 PM
This could be it. I'll have to phone my friend to see if the dimensions match what he needs. I bet he is not used to millimeters! Thanks.
Lehman57
Good Answers: 120
Re: Floor Plate Source?
09/26/2011 12:39 AM
Per Ardua Ad Astra
09/26/2011 12:45 AM
Wow! There are some neat ones in there. My checker-plate idea bombed out, but your page 1 row 4 pix 2&5 might work, along with Lyn's GA. Awaiting OP feedback....
09/26/2011 10:00 AM
Wow! Lots of images, but none seem to be what the guy wants. The pyramids in a square pattern of page 3 & 4 is closest, but he needs square flat-topped projections. It could be obsolete, because he is working on an old machine.
Lehman57
09/26/2011 2:08 AM
Seems to me that diamonds are just squares turned 45degrees. Am I missing something?
09/26/2011 2:14 AM
The "diamonds" in ordinary diamond-plate are elongated rhombi, about 3/8" x 1.5", alternating 90° from each other. Quite different from rotated squares.
Good Answers: 25
09/26/2011 2:49 AM
It is also known as chequered plates, normally used for walking platforms to avoid slipping. These are available in India but it will be expensive as shipping cost may be high.
09/26/2011 5:50 AM
Try "Manufacturers of chequered plates in India" .They may have such thing.What is the quantity required ?
09/26/2011 10:07 AM
He has not specified the quantity other than for floorboards on an Allis-Chalmers 220 tractor. So, probably small--my guess is several square feet .
Lehman57
Good Answers: 94
09/26/2011 7:14 AM
Also known as tread plate, here's some examples. No. 24 could be what you want.
09/26/2011 10:13 AM
Could be; I'll pass on the website. Cut at an angle, the squares would be in rows and columns.
Lehman57
Good Answers: 94
09/26/2011 4:30 PM
That site was a random choice, there are several manufacturers, maybe one closer to home.
09/26/2011 7:35 AM
L57,
Here locally (Stark County), try Ohio Gratings out on Southway. If they don't have what you need, they should be able to point you in the right direction. Also, R.G Smith Co. (local sheet metal fabricator) on Dueber S.W. could be a good source. Shop foreman's name is Chuck Rogers.
Good Luck !
"Money talks I know, I heard it once, it said Goodbye”
Register to Reply 20 comments
aurizon (1); B.J. (1); Dilip Dombivalikar (1); kramarat (2); Lehman57 (5); lyn (3); Nigh (2); Qwack (1); suresh sharma (1); Tornado (3)
