Previous in Forum: Space Technology   Next in Forum: RC Phase Shift Oscillator Theory
8 comments
Leakage in Electronic Appliance
09/24/2011 11:47 PM
Leakage current was found in the electronic devices (such as CPU in Desktop and slot machine in Casino) in our building.I would like to ask is it a common problem and how to rectify it?
Pathfinder Tags: electric current leak
Re: leakage in Electronic appliance
09/25/2011 12:22 AM
How are you sensing the "leaked" current? If this is all AC, then your statement: "is it a common problem and how to rectify it?" is quite the pun
09/25/2011 7:48 PM
Test pen light glow a bit and sometimes we can feel small electric short when use hand touching the metal casing of CPU in Desktop and slot machines and all the them are powered by AC power supply. The test pen light not lited anymore when our hand touching the metal body of the machine if a ground cable is connected to the ground terminal of the machine. Thanks.
09/25/2011 12:40 AM
Found how?
Is the voltage between a good ground and the ground of the bad device about 1/2 the line voltage?
09/25/2011 1:35 AM
AC powered device , if made of metal housing, should have its external hosing earthed permanently for safety.
The fact you detect leakage is that it is not earthed.
Certain detectable leakage is not unusual.Without earthing, if you use a test pen and touch the metal casing , the test pen may glow a bit, the glowing is due to current flowing through the test pen and your body to earth. These leakage current is due to poor insulation. There is a certain limit to this leakage when it is considered not save. The safest and correct thing to do is to ensure earthing the metal housing is there and good !
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
Good Answers: 141
09/25/2011 3:52 AM
Check for anti-parasites filters' condensers if applicable in the power supply. Most slots produce spikes that are normally filtered. (or completely blocked in the power supply)
Plenty of room here
Good Answers: 70
Re: Leakage in Electronic Appliance
09/26/2011 12:27 AM
Try moving to a Dollar slot machine and see if that ratifies the leakage? It maybe the machine's are programed to shock you until you satisfy the minimum dollar amount. Chic-Ching
Good Answers: 27
09/26/2011 10:01 AM
Due to what is known as leakage, stray capacitance, etc., all electrically operated devices have and /or develops "leakage current". The amount and magnitude of any unwanted leakage current can only be minimized Not totally eliminated!!
The use of a properly designed, low leakage Isolation transformer will help you limit this unwanted leakage current into the micro-ampere range.
vsar
09/26/2011 12:22 PM
Yes, I think you are part of a common problem in commercial business whom don't have the luxury to unplug their appliances when not in use.
For manufacturing applications, check USON: they make Leak Test Equipment for all types of manufacturers in Automotive, Medical, Industrial, and other industries. This is the guy to call:
Bob Cromleigh
CR4 Admin - phone number removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Register to Reply 8 comments
ampt (1); bravo88 (1); chua_hwachek (1); dj95401 (1); dvmdsc (1); KeepItSimpleStupid (1); Mikerho (1); vsar (1)
