Pls note the following conditions for propane dryer unit wherein water content from propane is removed using molecular sieve as a desiccant:
Inlet conditions:
Flow rate= 3520 kg/hr (max.), operating P & T= 24.4 kg/cm2(g) & 38 Degree C, water content= 2 kg/hr
Outlet conditions:
operating P & T= 23.7 kg/cm2(g) & 38 Degree C, water content<20 ppmW
We are technically evaluating 2 bidders who have quoted for the supply of dryer unit. One bidder has considered inlet water content in ppmW units as 650 and another has considered as saturated+325.
As we intend to find total moisture content removed by the dryer which is= Moisture at inlet- Moisture at outlet, please clarify how to arrive at ppmW value of water in propane at inlet, as 2 bidders have considered different values. However at outlet both are giving same ppm content as < 20 ppm as that figure is a guarantee parameter.
