Previous in Forum: Substation Charging   Next in Forum: Generator Battery
AC Motor Power
09/27/2011 1:23 AM
I have a simple doubt, i have a motor of 4.8KW and 32V line, if my induction motor works with a pf of .83 and 80% efficiency, as per the power equation,
p= 1.732*v*i*cos phi* eff
I=p/1.732*v*i*cos phi* eff
1)Is the current obtained is rms or full load?
2)Do we consider average power for motors?, since if take rms values of I and V we get averagepower
3) What is the difference between rated and average power?
Re: AC motor power
09/27/2011 2:39 AM
The first equation, P = √3 V I cosφ η, is correct. [I have taken liberties in editing.]
The second should read: I = P/(√3 V cosφ η). [The former "i" on the right was incorrect.]
1) Full load current (FLC or FLA) is used as a default value for sizing wires, circuit breakers, motor overload protection, and fuses. Once the motor is in service, it may actually run at other values of current. For power metering, load analysis, etc., you would then want to measure rms current.
2) Rated power is what the motor can produce, and is based on FLC or FLA from the nameplate.
Average power is what the motor actually produces, and is based on rms current, which may fluctuate with varying load. This is what the power meter measures.
[I wanted to italicize "actually" in the last sentence, but for some strange reason, after a few lines into a post, the ability to select and format text seems to vanish. Does anyone know why?]
Re: AC motor power
09/27/2011 3:55 AM
Sorry it was my mistake of writing current eqn as given actually i meant the current eqn as you have given.
Now from the above conditions i get the current as 105A, will this be rms or full load value, and does the full load current means Irms*1.414?
please correct me
Re: AC motor power
12/08/2011 12:40 PM
The figure will be the full load current Irms. Leave the √2 out of it.
Register to Reply 3 comments
PWSlack (1); sujinvipin (1); Tornado (1)
