Previous in Forum: marine pipe vent caps   Next in Forum: What is Corresponding Material in ASME Code for 'Stainless Steel 304'?
Metal Flushing Line for Vertical Pumps
09/28/2011 10:35 PM
In vertical pumps (VS4) with separte discharge , the vendor installed metal flushing line from discharge going to each sleeve bearing in the shaft. How does it works and its importance? Many thanks...Godbless...Peace
Re: METAL FLUSHING LINE for VERTICAL PUMPS
09/28/2011 11:59 PM
One thing it does is cool the bearings; if liquid did not circulate, the bearings would heat up. If the fluid has lubricating qualities, it will also provide lubrication to the bearings.
09/29/2011 1:14 AM
Thanks Tornado for your inputs...I am sorry coz I am only newbie..Godbless..Peace...
09/29/2011 1:46 AM
Glad to help, and welcome to CR4.
(Another thing you might see, which could look roughly similar, is an equalizing tube for decreasing axial forces on an impeller; sometimes called a "balance line".) As you gain more exposure to pump designs, you will see a number of arrangements for various purposes.
09/29/2011 2:04 AM
(Another thing you might see, which could look roughly similar, is an equalizing tube for decreasing axial forces on an impeller; sometimes called a "balance line".) As you gain more exposure to pump designs, you will see a number of arrangements for various purposes. There are several pump experts here on CR4 who can give you good advice.
Register to Reply 4 comments
