Previous in Forum: Metal Flushing Line for Vertical Pumps   Next in Forum: Overall heat Transfer Coefficient for a Graphite Condenser
What is Corresponding Material in ASME Code for 'Stainless Steel 304'?
09/29/2011 1:40 AM
What is corresponding material in ASME code for 'Stainless steel 304'? And what is the Ultimate tensile strength and allowable stress for SS 304?
Paresh B. Gujarati
Re: What is corresponding material in ASME code for 'Stainless steel 304'?
09/29/2011 3:09 AM
Look it up. You do know how, right?
Re: What is Corresponding Material in ASME Code for 'Stainless Steel 304'?
09/29/2011 10:02 AM
Refer ASME SEC II_D & II-A.
EIL
09/29/2011 1:00 PM
At least make some efforts before coming to this forum!!!
09/30/2011 2:37 AM
Dear Mahesh. Who force you to answer the question? I want some specific and correct answer so I posted this questions. I have not kindly request you to reply to my post. We know ASME section II is for material properties. Thanks for your time.
If you do not have any answer at least shut your mouth. Thanks.
Paresh B. Gujarati
10/02/2011 7:22 PM
Greeting to you
First you must know that S.S 304 not the main designation of the material but it grade in each material in S.S materials and there is another grades like 304L, 310, 316, 347,…. Etc.
The grade of 304 is the low-grade in stainless steel materials.
the value of tensile strength and allowable stress change from material to another material and you can get all of these values from ASME sec II part A or PART D
And here you are the most common material ( stainless steel ) in each application:
For plates SA 240 grade 304 , 304L ,310, 316, ….., 347,…etc.
For pipes SA 312 grade …………………………
For tubes SA 213 ……………………………….
For forgings SA 182 ……………………………….
For fittings SA 403 …………………………
For bolting SA 320 grade B8 with SA 194 - 8
And remember that stainless steel material mean that these material which have chemical composition of Cr % greater than 11 %.
enlightenment is blessing and self-denial is a good recipe
blackpanic73 (1); lyn (1); mahesh_4754 (1); Mayank.Technip (1); paresh_career001 (1)
