Previous in Forum: What is Corresponding Material in ASME Code for 'Stainless Steel 304'?   Next in Forum: Restriction Orifice
9 comments
APIX Pilot Plant Design Project - Member - New Member Engineering Fields - Chemical Engineering - Member Engineering Fields - Environmental Engineering - New Member
Overall heat Transfer Coefficient for a Graphite Condenser
09/29/2011 2:32 AM
I am trying to find a good approximate value for the H.T. coefficient for a shell and tube Heat Exchanger where I am trying to condense water at about 50 deg C (reduced pressure) with water at about 15 deg C.
I am able to find these coefficients in various chemical and mechanical engineering handbooks. But they don't mention a MOC of the condenser. I assume they mean Steel:Steel?
Please help.
Shalom
Re: Overall heat Transfer Coefficient for a Graphite Condenser
09/29/2011 3:08 AM
Of course, the obvious answer is to ask someone who makes (and sells) them.
Otherwise, look at materials web sites.
This doesn't seem like a good application for graphite composites. They don't like water.
09/29/2011 3:21 AM
I forgot to add, the water has hydrochloric acid also in it.
We're choosing graphite over glass here.
Shalom
09/29/2011 3:56 AM
Ah. So it's not water. It's aqueous hydrochloric acid instead. What strength?
09/29/2011 4:26 AM
About 20% by weight. Manufacturer says about 100 W/m2K. Don't you think it is too low keeping in mind the U for SS in a similiar set-up is 1000-4000 W/m2K?
Shalom
09/29/2011 4:46 AM
<...I am trying to find a good approximate value for the H.T. coefficient for a shell and tube Heat Exchanger where I am trying to condense water 20% hydrochloric acid at about 50 deg C (reduced pressure) with water at about 15 deg C.
Please help....>
Is this correct?
HTCs depend upon, among other things, fluid composition, velocity, and turbulence as well as wetted material thermal conductivity and thickness. It is not possible to give a reasonable respoinse to the other questions without a detailed look at the geometry of the heat exchanger, for which the manufacturer is in the best position to advise. In particular, it would be crucial to know that 20% hydrochloric acid is the process fluid, rather than water.
One presumes the manufacturer's telephone number is to hand? After all, one wouldn't want to over- or under-size the exchanger for the process application, the details of which have not been shared with the forum; presumably they are commercially sensitive.
09/29/2011 4:51 AM
yes
Shalom
Good Answers: 12
09/29/2011 5:45 AM
I know this company; Contact them and they will be able to help you.
www.graphiteindia.com
Subramanyam
10/20/2011 6:10 AM
provide the exact thermal data. Flow rates ,temepratures and properties. I will do approx preliminary design for you.
RK
03/07/2012 2:33 AM
Hello! I am having the same problem as Zasmine had. Thankfully, I got some great suggestions here. I hope more discussions will further help me. Thanks!
Register to Reply 9 comments
brkmech (1); DeclanJustin (1); kvsubramanyam (1); lyn (1); PWSlack (2); zasmine (3)
