Previous in Forum: Overall heat Transfer Coefficient for a Graphite Condenser   Next in Forum: ASME Sec VIII Div: 01-Flange Design
16 comments
Restriction Orifice
09/29/2011 3:23 AM
we have already purchased one multistage water pump of capcity 20m³/hr@ 290MLC.
I have calculated system resistance for 20m³/hr flow through 80NB line for 15m static head & total length around 280m with 25 bends & all necessary fittings ,it comes around 120M.
Now my pump is designed for 20m³/hr@ 290MLC,to avoid the run out condition due to less system resistance of 120m,i will have to put restriction orifice to get total system resistance near about 290M.
Please guide me what size & how many restriction orifice I will have to put in discharge line.
If u have any calculation to calculate orifice size,please share it.
Re: restriction orifice
09/29/2011 3:37 AM
Instead of a fixed orifice, you might also consider a needle or expansion valve, which can be adjusted for various conditions.
Some pump manufacturers may have already designed a suitable "Q-max" orifice in advance, and furnish it as part of the total pump package. (I have worked with refrigerant pumps where this approach was taken.)
If you present this same question to some pump suppliers, they will quite likely be able to advise you. (If you give them full datails of your piping.)
09/29/2011 3:51 AM
There are variable orifices. They are called "valves".
Good Answers: 137
09/29/2011 5:47 AM
Trying to kill 170m over an orifice could be a problem - cavitation etc. Have you considered changing to a lower speed motor? If your current one is 4-pole and you change to 6-pole, it will deliver 20*2/3 = 13.3m³/h at 290*(2/3)2 = 129m. It might do 20m³/h at 120m, you can check by plotting the system and new pump curves.
You can also check new power drawn, which will be much lower, so save a lot of energy too.
Codey
Re: Restriction Orifice
09/29/2011 11:53 PM
You can add more bend to come around 290MLC. calculate the extra bends and length and reroute your piping.
09/29/2011 11:54 PM
Alternatively use a variable speed drive (VSF, VFD, ASD - all effectively the same), simply ramp up the drive until the pump is achieving the flow required.
This is far more energy efficient, as you are not wasting energy by restricting the flow (valves, orifice plates, etc). When you consider the long term energy costs, and reduced pump/motor wear, these drives are easy to justify.
Hope this helps.
Anthony
09/30/2011 10:41 AM
GA
With a VFD he can keep the same pump (no impeller reduction...) and tune the speed (rpm) to achieve the same flow at the back pressure available.
09/30/2011 1:00 AM
Reducing speed through VFD will also reduce the flow. If you can share the pump characteristics then I can examine if by reducing the impeller diameter you can achive the required head and flow.
Good Answers: 21
09/30/2011 2:35 AM
I see no actual calcs yet. Try this site...very good.
www.pipeflowcalculations.com
Location: Base in Madrid, Spain. Updated location every several months.
09/30/2011 5:59 AM
If the excess of pressure at the end is a temporary condition, I would suggest to use a valve (it is known as "throttle adjusting") .
If this condition remains above certain amount of or all the time, the use of a VFD is advisable technically and economically.
Also change the motor for one of a lower speed (check thoroughly!) could do.
To evaluate economically, check: estimated running time, VFD cost, valve cost, new slower motor cost, electrical savings for each case (I would say you could save around 50% with the VFD or new motor), , and make your maths to find the more convenient solution.
Everyday learning.
Good Answers: 11
09/30/2011 12:17 PM
Dear santoshp9, are you listening the advices of learned members, please respond.
If you are yet to lay 80 NB pipe, so far only thinking and calculating then I have one more advise to offer. Change your plan for 50 NB pipe and fittings. You will get double benefit, higher resistance with much lower cost.
When there is smoke, there must be fire.
10/01/2011 12:12 AM
Dear sir,
If I go for 50 NB pipe the velocity through it will be around 4.5m/s.There is chances of errosion of pipe.Recommended velocity for 50NB pipe is not more than 1.5m/s as per design criteria.
10/01/2011 10:23 AM
You have got many practical solution to your problem. Now comes the next step to choose most appropriate solution which can give you intial as well as running economics suitable to the system. VFD is costly afair but if your requirement needs frequent changes in flow and head then go for VFD. Changing motor RPM seems most suitable solution as well as you can try using smaller impeller but lower RPM machine's wear and tears are less and pump runs more stable.
Good Answers: 11
10/03/2011 5:25 AM
No, your calculation seems to be wrong. For 50 NB pipe the velocity through it will be around 2.5 m/s for your required flow rate of 20 m3/hr. Piping velocity of 2-3 m/s is OK for your application.
10/03/2011 8:38 PM
I agree with this. Keep the velocity less than 1.5 m/s. Higher velocity brings in other factors which need be considered (such as water hammer - although at NB50/80 you're pretty safe). From my experience, keep the velocity less than 1.5 m/s (and it solves many issues).
Cheers
Anthony
Good Answers: 179
09/30/2011 1:56 PM
I'm not sure what type of pump you have purchased, but if it is a centrifugal pump you can have the pump supplier "trim" the pump impeller in order to get to the design duty point. This would be the cheapest alternative for you. Otherwise if you can swallow the outrageous cost go for a different motor size or VSD.Remember, most pump distributors will charge you a "Restocking" fee for returning any pump or motor.....basically it's highway robbery IMO by the bastards and just pads their profit margin (sounds like a bank and their service charges, eh????)
09/30/2011 11:57 PM
According to pump laws for same speed flow is proportional to the diameter and head is proportional to square of diameter. Trimming the impeller without examining the characteristics of the pump will bring down the flow although the head will be achieved.
Register to Reply 16 comments
abelmh (1); ajwinemaker (2); CaptMoosie (1); Codemaster (1); Hilton (1); LAA_Lucke (1); Learner42 (2); Mukesh0861 (1); prdp2344 (2); PWSlack (1); santoshp9 (1); Tornado (1); upendra Kumar (1)
