Previous in Forum: Mechanical Engineer   Next in Forum: Generator Circuit Breaker: Can MV Cubicle Replace GCB's Function?
Busbar Contact Resistance
10/01/2011 2:11 AM
Could any one please tell me the minimum acceptable value for BUSBAR contact resistance?.. with references like IEC,BSI,IEE is highly appreciated.
Re: Busbar contact Resistance
10/01/2011 2:17 AM
Zero.
10/03/2011 6:04 AM
Quite. It's just so difficult to get negative resistance these days...
10/01/2011 6:01 AM
"Could any one please tell me the minimum acceptable value for BUSBAR contact resistance?.. with references like IEC,BSI,IEE is highly appreciated."
You need to alter your question.
Perhaps this format will get you the information you desire.
Could any one please tell me the acceptable range for BUSBAR contact resistance?.. with references like IEC,BSI,IEE is highly appreciated.
Lyn has kindly given you a start for this range..
India - Member - New Member
Good Answers: 164
10/01/2011 7:48 AM
Another option perhaps.....
"Could any one please tell me the maximum acceptable value for BUSBAR contact resistance?.. with references like IEC,BSI,IEE is highly appreciated."
Well. A rose by any other name etc... Nothing will get any useful answer, given the negligible data provided.
Good Answers: 15
Re: Busbar Contact Resistance
10/01/2011 10:48 PM
I have not searched in the codes for an answer because i have serious doubts whether a specific universal answer exists . . .
I advise you to restate, for yourself, your concern to know what the joint contact resistance should be in relation to the total resistance of the busbar . . . also note that differently acceptable ranges values may be have to exist for different voltage conditions, materials used and types of joints (brazed or riveted or bolted or cold pressed or clamped).
Many references are available to help you with the knowledge you seek . . . some are listed below . . when you read through you will find others who have asked this question before you . . . do contact them and find out what they have learned in the period between asking the question and now . . . their learning(s) may often be more pertinent and focused than that of "experts" who may know more and share more than you need (or want) to know . . .
If still in doubt . . . do come back . . .
ref:
http://cr4.globalspec.com/thread/71091/Overlapping-Length-for-the-Busbar-Joint
http://cr4.globalspec.com/thread/62056
http://cr4.globalspec.com/thread/62136/Contact-Resistance-of-Busbar-Joints
http://cr4.globalspec.com/thread/50934/Busbar-mV-Drop-Test
http://www.copperinfo.co.uk/busbars/pub22-copper-for-busbars/sec7.htm
http://www.advancedprobing.com/pdfs/contact-resistance-1.pdf
http://www.advancedprobing.com/pdfs/contact-resistance-2.pdf
Good Answers: 164
10/02/2011 2:05 AM
Register to Reply 6 comments
kvsridhar (2); lyn (1); PWSlack (1); soebfatehi (1); woodygb (1)
