Previous in Forum: Instrument Design Verification..   Next in Forum: Vortex Flow Meter
Canada - Member - New Member
Motorised Valve or Pneumatic Valve is Best
10/01/2011 8:21 AM
hi,
For a project i need to install a valve in water line which as temp from35 to 40c .so kindly
suggest whether Motorised or Pne valve is best? and explain why?
Re: MOTORISED VALVE or Pneumatic valve is best
10/01/2011 8:37 AM
ZORANDODO
Good Answers: 266
10/01/2011 10:01 AM
Electrically operated valve. If the there is any distance from the power sources. Conduit and wire is less expensive the black pipe or air line. Cost of the valves are about the same. With pneumatics you may have to provide some air treatment and regulation(psi) which is extra cost. With pneumatics if compressor goes down you lose function if electric you don't. If electrical power goes down you lose both anyway.
Now whats the function of the valve it mat make a difference?
Re: Motorised Valve or Pneumatic Valve is Best
10/01/2011 10:51 AM
Is this a test?
10/01/2011 11:56 PM
ozzb is right.
Normally you have more control with electrical signals than Pneumatics. U can also control the flow with a motorised valve and PID control system.
For Motorised valves, you have 2 types:
Gate Valve and Butterfly Valve.
i prefer gate valve as its life is longer than butterfly valve. However, the availability depend on the size of pipe you are using.
10/02/2011 5:01 AM
For quick response, pneumatic is likely to be best. Otherwise, I would tend toward electrically motorized. It depends on how rapidly the process may fluctuate.
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
10/02/2011 5:27 AM
The only data given, water @ 35-40C doesn't affect the selection.
You want an on-off valve, a modulating valve? You want a fail open/close/as is operation? Valve size? Which system and differential pressure? Stroke time is essential? All this and similar data will give you the thrust/torque you need to move the valve and this will assist you in the selection, usually motor operators have a higher force rating, but most of them are for on-off actuation (modulating function need a different motor power/size). Air operated are used for both applications (on-off and modulating). The later need more instrumentation (positioners, maybe volume boosters...)
Kind regards
10/04/2011 7:49 AM
We use electrically motorized valves in larger and plastic lines for throttling flow and to reduce the effect of (water hammer). The electric valves we have are designed to return to a safe position in the event of a power failure by spring action. Pneumatic valves would be a good choice in hazardous locations where flammable vapours may be present.
Knowledge makes what was impossible, seem easy.
Register to Reply 7 comments
Elroy (1); Kwetz (1); lyn (1); ozzb (1); Tek (1); Tornado (1); ZORANDODO (1)
