Previous in Forum: Difference Between Basic, Hydrostatic and Hydrodynamic Bearings   Next in Forum: Testing Set Up for Drum Filling Machine
Difference between GRVE and GRE
10/02/2011 3:02 AM
What is the Difference between GRVE and GRE. we can use GRE instead of GRVE.
Re: Difference between GRVE and GRE
10/02/2011 3:07 AM
Unexplained Abbreviation Alert!
10/02/2011 4:11 AM
Yes.
GRVE Pipes
GRVE Pipes are made from the dual helical winding technology. The major raw materials used for this are fiber glass, Vinyl Ester resin and sand (certain cases). Inner liner consists of surface tissue and Vinyl ester resin for maximum chemical resistance and will enhance abrasion resistance. The structural layer consists of E- glass and Vinyl Ester resin. Outer Liner is a thin layer with structure similar to the structural layer. GRVE Pipes have better mechanical and chemical Properties when compared to GRP Pipes.
Diameters of pipes produced range from 25mm to 2000mm currently.
GRE Pipes
GRE Pipes are made from the dual helical winding technology. The major raw materials used for this are fiber glass, Amine Cured Epoxy resin and sand (certain cases). Inner liner consists of surface tissue and Amine Cured Epoxy resin for maximum chemical resistance and will enhance abrasion resistance. The structural layer consists of E- glass and Amine Cured Epoxy resin. Outer Liner is a small layer with structure similar to the structural layer.
From Smithline Pipe website.
10/02/2011 4:23 AM
May I further distill to Glass Reinforced Vinyl Ester and Glass Reinforced Epoxy?
10/02/2011 12:22 PM
The letter "V".
One can have a wonderful GREat day and one tragic GRaVE day.
You can use both equally well, but they will always mean something different because they have different letters.
Now everybody sing along with me... "One of these things is not like the other...."
06/17/2015 1:28 PM
GRE stands for Glass reinforced epoxy
GRVE stands for Glass reinforced vinyl ester
For both glass can be chop strand or helical wound. Epoxy resin or vinyl ester type is chosen based on the application such as type of fluid temperature, pressure and pH. It is possible to find the type of resin in either Epoxy or vinyl ester to meet the engineering criteria. They are of different chemistry that's all.
lyn (1); redfred (1); Tornado (2); Vijay436 (1)
