Previous in Forum: ELCB   Next in Forum: Transformer
11 comments
Indicator
10/02/2011 1:09 PM
Dear all,
My machine Indicator having 240 volt supply. It is going through transformer or SMPS to become 9 volt.. Is it possible to give supply through charger.
Plase tell me if you need any information as I am not electrical / electronic Engg.
may be I am not giving you full information .
Please tell me if you need any information.
Regards.
thoughts becomes things.
Re: Indicator
10/02/2011 3:28 PM
"Is it possible to give supply through charger."
Yes, proper charger. Or, power supply.
Re: Indicator
10/02/2011 5:16 PM
Sandy
I want to be sure we understand. What do you mean by charger?
Something like a battery charger?
Good Answers: 12
Re: Indicator
10/03/2011 1:57 AM
First check voltage rating of the lamp Bulb. If it is matching you can connect charger. Some modern indicating lamps are using single big bright light LEDs and some few small LEDs mounted on a small PCB. Hence you need to check this first.
Subramanyam
Re: Indicator
10/03/2011 12:35 PM
ok
I will check LEDs rating.
Do you mean to say only cause of this LEDs we are giving 240 volts.
As per customer Requirment we are giving in built 6 Volt battery in Indicator.
It is running fine on Battery. Then why we are giving 240 volt.
Why not charger / adopter type 6 volt or 9 volt supply.
I think we can save tranformer and EMI filter money.
As well as we can make Indicator more compact.
Please advice.
Regards.
Re: Indicator
10/07/2011 1:56 PM
Dear All,
I come to know because of IP rating we are not going for adopter.
We are not getting IP 67 adopter.
Please Advice.
Re: Indicator
10/07/2011 3:19 PM
Not enough information for me to be able to help further, bye.
Re: Indicator
10/08/2011 12:33 PM
Is there anybody who can supply us IP 67 protected charger or adopter.
Re: Indicator
10/10/2011 11:12 AM
We need 230V AC to 12V AC Adopter.
Is there any AC to AC Adopter.
Re: Indicator
10/10/2011 1:26 PM
Yes, we call it a transformer......
But there are also ones built into plastic boxes and even ones called "Wall-Warts".....
Re: Indicator
10/03/2011 3:25 AM
In principle no as the charger voltage may be, when not charging a battery, far far higher than the voltage you want!!!
Re: Indicator
10/03/2011 8:35 AM
It is possible only if charger has rating of the indicator power wattages.
Exploring the Science of Electricity
Register to Reply 11 comments
Andy Germany (3); harry potter (1); kvsubramanyam (1); lyn (1); sandeep lokhande (4); wareagle (1)
