Previous in Forum: Earth rod required for sewage pumps and control panel   Next in Forum: Continuity test for embeded 16 sqmm copper earth conductor
For 11kV Dist Network, Earth Rod Required for Grounding Manholes Rebar and Metal
10/05/2011 8:56 AM
We used 120 sqmm bare embeded copper earth conductor parallel to 11kv cable duct banks for grounding the cable supports and Manhole accessories this conductor grounded at main substation and secondary substations. Is it required the earth rod at each manholes to ground the cable supports and metal accessories at each manholes.
Good Answers: 181
Re: for 11kv Dist network, earth rod required for grounding Manholes rebar and metal
10/05/2011 5:56 PM
UK practise is earth at each joint. Check your local codes.
Good Answers: 58
10/06/2011 12:21 PM
Try this
and this
Register to Reply 2 comments
