Previous in Forum: Continuity test for embeded 16 sqmm copper earth conductor   Next in Forum: Voltage Rating for 6.6 kV Neutral Earthing Resistor
Can Grounding Grid Conductor 120 sqmm be Used as a Service Conductor
10/05/2011 9:44 AM
Please advise us for a District cooling plant we have a grounding grid of 120 sqmm pvc insulated copper conductor of mesh 5 meterx 5 meter and 70 sqmm grounding riser to ground the equipments like switchgear, transformers, generators, pumps cable tray and panels. the separate service grounding conductor required or no for motors, ATS and 6.6 kv MCC feeder cables, or grounding grid conductor is sufficient to use as a service grounding.
Re: Grounding grid conductor 120 sqmm can be used as a service conductor
10/05/2011 9:54 AM
Hire a qualified Electrical Engineer locally to assess it.
Good Answers: 444
10/05/2011 12:51 PM
PVC insulated copper conductor mesh??? I thought the goal was to have as much contact as possible with the "ground" by using bare copper....
Good Answers: 181
10/05/2011 5:51 PM
Interesting concept, I wonder if it will catch on?
Stop all those naughty electrons running away
Register to Reply 3 comments
PWSlack (1); RAMConsult (1); TonyS (1)
