Previous in Forum: Compressibility Factor Chart or Table for Helium Gas   Next in Forum: Sand Blasting
Purification of Zinc Sulphate Solution
10/05/2011 1:44 PM
Zinc sulphate (Mono-hydrate) is used as fertilizer, in textile & also as feed ingredient. But sometimes it is not indicated properly on the bag. Can any one tell me what may be the easiest way to purify the solution into feed grade if the original solution was not pure?
Re: Purification of Zinc Sulphate Solution
10/05/2011 3:03 PM
It depends entirely on what the impurities are.
(need more info)
10/05/2011 11:49 PM
Actually I don't know what types of impurities do exist in zinc sulphate from China origin. My attention is toward Cadmium & Dioxins especially.
10/06/2011 9:33 AM
You have 2 choices here:
1) Buy a higher grade of chemical that comes with a Certificate of Analysis.
2) Have the material from China analyzed for RoHS and other toxics, then figure out a way to purify to acceptable standards for the use intended. This will entail further and ongoing testing. The cost of the ZnS may be cheaper, but consider the added cost to test and purify.
10/06/2011 12:51 PM
Thanks. I'll try to purchase higher grade, if it could be found. Otherwise it would be so costly.
10/07/2011 4:52 AM
The cost of killing those who ingest dioxins is much greater.
10/08/2011 7:55 AM
Certainly. That has to be kept in mind always.
Register to Reply 6 comments
Mikerho (2); PWSlack (1); SYED MD. ANWAR UL ISLAM (3)
