Previous in Forum: Pressure Switch or Flow Meter?   Next in Forum: Turbine Flow Meter
Flow Transmitter
10/10/2011 3:10 AM
How to calibrate a new Flow Transmitter (DP type)?
Re: Flow Transmitter
10/10/2011 3:59 AM
One cannot. One can only calibrate the thing for pressure against a dead-weight tester.
Good Answers: 183
10/10/2011 5:56 AM
Usually sensors or transmitters do come calibrated by the factory. Depending on what for a fluid you measure and which is the flow magnitude it is possible to calibrate it "in house" but the process is complex. Any way it is possible ONLY for small flows.
10/10/2011 9:12 AM
hi first I want from you the type of transmitter is it digital or analog , then I can help you bye ali
Register to Reply 3 comments
aladdin (1); nick name (1); PWSlack (1)
