Previous in Forum: Bridle Design for Pressure Vessel   Next in Forum: Has Anyone Tried IGBT IXGX72N60C3H1?
How to Increase Control Valve Response
10/10/2011 8:06 AM
Hi,
can any body help me for the issue " How to increase the response time of a control valve".
Re: How to increase control valve response
10/10/2011 8:13 AM
Good Answers: 19
Re: How to Increase Control Valve Response
10/10/2011 11:05 AM
Changing the valve trim or changing the actuator (say from electric to pneumatic) can alter a valve's response. Sometimes the actuator's response is limited by settings in the positioner, so changing the settings in the positioner can provide faster actuator response and hence valve response.
If the question was really, how to increase the process response, then loop tuning is the first place to look.
10/11/2011 4:05 AM
Two options:
  1. Slug the signal with a low-pass filter.
  2. Introduce transmission delay.
Either will introduce instability into the control loop, which will therefore require re-tuning.
10/12/2011 9:04 AM
First, do you want to increase the response time, or decrease the response time?
Register to Reply 4 comments
Bud (1); kramarat (1); lyn (1); PWSlack (1)
