Previous in Forum: Acceptable Metal for Heat Exchanger for Liquid Silicate Solution   Next in Forum: Suitable Adhesive
12 comments
Removing Chroium Plating From Copper-Based Wires Without Using Acids
10/11/2011 12:32 AM
How can chromium plating be removed from copper-based wires about 0.060" in diameter without using strong acids or bases? Methods based on the use of buffered aqueous solutions are preferred over purely-mechanical methods such as grit-blasting. The close proximetry of the wires to heat-treated austenitic stainless steels make the use of strong acids or strong bases unacceptable, as the stainless steel would undergo intergranular corrosion..
Re: Removing Chroium Plating From Copper-Based Wires Without Using Acids
10/11/2011 7:43 AM
Have you considered electrolysis?
10/11/2011 9:42 AM
A couple of off the wall ideas, but easy enough to try.
1) Try soaking in coca cola.
2) Try freezing them. If the copper remains pliable, and the chrome becomes brittle, you may be able to just flex the wire and shatter the chrome on the outside, allowing it to fall off.
10/11/2011 10:29 AM
Melting point of copper 1083C
Melting point of Chromium 1613C
Heat it to 1300 ...
10/11/2011 10:35 AM
I was thinking that he still wanted wire when he was done.
10/11/2011 11:12 AM
Yeah and he probably wants the moon on a stick too... there's no pleasing some people, I remember when I was a kitten we were lucky to get a bit of string to play with
10/11/2011 2:56 PM
When I was a pup we got a piece of kitten to play with.
10/11/2011 3:18 PM
I'm grown and I still enjoy a piece of kitten every once in a while.
10/11/2011 7:39 PM
Can you say double entendre boys and girls?
Good Answers: 151
10/12/2011 7:59 AM
Yes, this looks like a good place to strip the chrome.
Good Answers: 120
10/11/2011 10:25 PM
In the metals business they call this chrome stripping.
Look through these link and see if they have a stripper to remove chrome from a base layer of copper.
Cyanide based chrome stripping
chrome stripping organic
Per Ardua Ad Astra
10/11/2011 11:44 PM
Why do you want to? The bare copper will then be prone to oxidation?
10/12/2011 6:09 AM
Try de-plating ( Revere the polarity)
if you are a managment professional or youth who wants to start business contact for free help for your project including financial assistance through NGO in and around Pune India
Register to Reply 12 comments
Anonymous Poster (1); aurizon (1); gringogreg (1); kirannawathe (1); kramarat (3); lyn (1); Usbport (1); user-deleted-1105 (2); WAWAUS (1)
