Previous in Forum: Fillet Weld Size for Nozzle / Shell Joint (Div 2)   Next in Forum: SA 312-Tp316 Instead of SA335-P91 Material
10 comments
PressBrake Indexation
10/11/2011 5:24 AM
Just a quick question on a down stroke pressbrake, does the numerical value of the Y Axis increase when the Y Beam is raised or does the value decrease.
My feeling is that the when the Y Axis is raised the value would decrease!
The reason that I ask this question is that other persons have tried to repair this fault before I got to it and I am not sure of the axis orientation, but I have a feeling that when you index a pressbrake the value is decreasing.
Any ideas
Best Regards
Joe
Good Answers: 181
Re: PressBrake Indexation
10/11/2011 11:55 AM
The machines I've worked on had XYZ axis control, at the home datum all were zeroed. All positions were then positive in relation to home.
10/11/2011 8:31 PM
Indexation a word is not. Indexing proper word would be.
Good Answers: 19
10/12/2011 12:21 AM
Poetic license. Analogous to vexing-vexation.
10/12/2011 2:38 AM
Sorry Mikerho
Just so I won't forget I have done some lines for you.
No No that doesn't sound right, how about
Indexation is a word according to CR4 spell check, please take this up with CR4
Now lets look at you grammar "Indexation a word is not. Indexing proper word would be" is this Shakespeare?????
Wouldn't it have been better to say "To Indexing and not to Indexation".
Best Regards
Joe-speare
Good Answers: 110
10/12/2011 12:23 PM
I think he meant "indexificational positioning paradigms".
Think big. Drive small.
10/11/2011 11:11 PM
Same as TonyS our presses all zero when blade is fully raised and count in the positive direction on the down stroke
10/12/2011 1:33 AM
Thanks Tony and Grochy, you are correct I changed the encoder A and B Channels around and it works fine.
Best Regards
Joe
Good Answers: 181
10/12/2011 9:28 PM
Good outcome
Good Answers: 110
10/12/2011 12:20 PM
In practice this stuff varies. 1. It depends upon where "home" is. 2. It depends upon convention. 3. Most machines can be made to work either way.
I think your understanding is correct, most of the time.
10/12/2011 11:15 PM
4. It depends on type of controller being used
Register to Reply 10 comments
bubbapebi (1); Grochy (2); Joe Sparky (2); K_Fry (2); Mikerho (1); TonyS (2)
