Previous in Forum: Generator Problem   Next in Forum: VECTOR DRIVES(VFD) - VARIABLE FREQUENCY DRIVES?
IP 32 Grade Control Panel
10/11/2011 6:21 AM
can any one send me IP 32 grade control panel photo
also i want to know about about vibration resistance 1.5G & shock resistance 20G, how can it will be achieve.
PLEASE REPLY ME ASAP.
THANKS.
Re: IP 32 GRADE CONTROL PANEL
10/11/2011 6:25 AM
http://en.wikipedia.org/wiki/Ingress_Protection
An electrical item on the floor inside an upturned bucket is IP32.
Re: IP 32 Grade Control Panel
10/11/2011 7:45 AM
Check the below details for IP classification.....
Degrees of Protection - First Digit
The first digit of the IP code indicates the degree that persons are protected against contact with moving parts (other than smooth rotating shafts, etc.) and the degree that equipment is protected against solid foreign bodies intruding into an enclosure.
0No special protection
1Protection from a large part of the body such as a hand (but no protection from deliberate access); from solid objects greater than 50mm in diameter.
2Protection against fingers or other object not greater than 80mm in length and 12mm in diameter.
3Protection from entry by tools, wires, etc., with a diameter of thickness greater than 1.0mm.
4Protection from entry by solid objects with a diameter or thickness greater than 1.0mm
5Protection from the amount of dust that would interfere with the operation of the equipment.
6Dust tight.
Degrees of Protection - Second Digit
The second digit indicates the degree of protection of the equipment inside the enclosure against the harmful entry of various forms of moisture (e.g. dripping, spraying, submersion, etc.)
1Protection from dripping water.
2Protection from vertically dripping water.
3Protection from sprayed water.
4Protection from splashed water.
5Protection from water projected from a nozzle
6Protection against heavy seas, or powerful jets of water.
7Protection against immersion.
8Protection against complete, continuous submersion in water.
There are no shortcuts on the road to a great experience.
Anonymous Poster #2
10/11/2011 8:42 AM
"PLEASE REPLY ME ASAP" No. Shouting a demand is still rude even if you add "please" to it Now go to your room and come back when you can act like an adult.
10/11/2011 8:55 AM
<...ASAP...>
New Year's Eve 2015 is "P". Is that OK?
Good Answers: 58
10/11/2011 9:45 AM
"New Year's Eve 2015...."
but....but.....no one will be here after December 21, 2012................sigh
Anonymous Poster (1); Aseer (1); KJK/USA (1); PWSlack (2)
