Previous in Forum: Need Help for Wire Wound Resistor   Next in Forum: Breaker Explanation
VA Rating of MCB, Contactor and Overload Relay
10/12/2011 6:04 AM
How to calculate VA rating of MCB, contactor and overload relay.
Re: VA rating of MCB, contactor and overload relay
10/12/2011 6:11 AM
The rating is the maximum breaking voltage multiplied by the maximum passing current.
10/12/2011 6:20 AM
HAI GOODDAY
Normally the power is calculated by voltage * current * powerfactor
if its VA means we calculate without powerfactor.
so VA rating = Line Voltage * Line current
Thanks & Regards
GIRITHARAN.R
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
India - Member - New Member
Good Answers: 164
Re: VA Rating of MCB, Contactor and Overload Relay
10/12/2011 7:50 AM
An MCB's main function is protection against overcurrent...so the making/breaking capacity quoted for an MCB is as has been said. It has elements within it to sense overcurrents (usually bimetallic and magnetic protective elements) and trip the device.
A contactor is a switching device whose main function is to switch on and off a motor (mainly) under normal and occassionally, abnormal conditions. There is no inherent intelligence within a contactor to sense an overcurrent.
An overload relay is a purely overload sensing device mainly for motors. It usually can sense an unbalanced (and single-phase) condition also, which is unhealthy for the motor. It has NO current-breaking capacity. In the event of an overload, it interrupts the coil supply to the contactor, which trips and prevents the motor getting damaged.
India - Member - design engineer Engineering Fields - Electrical Engineering - New Member United Arab Emirates - Member - New Member
10/12/2011 8:33 AM
its easy, V x A.
shamith gambhir, electrical engineer
Good Answers: 164
10/12/2011 9:21 AM
i should actually have said this before ....
Transformers are rated in VA (kVA, MVA etc) indicating the power that they can handle.
MCBs are rated in breaking capacity, in kA, and their current carrying capacity. Circuit Breakers used to be rated in MVA breaking capacity, but not any more.
Contactors are rated in their power handling capacity, usually kW or HP, since most of them are used for motor control. They are not rated in kVA. (Special capacitor-switching contactors are rated in kVAR).
Overload relays are rated in Amps. Nothing else (ok, trip classes are also specified sometimes, but no VA or anything like that)
Why do you need VA of these things ?
giri.gtr2010 (1); kvsridhar (2); PWSlack (1); SHAMITHGAMBHIR1 (1)
