Previous in Forum: Extending Calcium Hypochlorite   Next in Forum: Sodium Petroleum Sulphonate
9 comments
Making Grease from Palm Kernel Oil
10/13/2011 8:53 PM
What is the process by which grease be made using palm kernel oil?
Re: grease making
10/13/2011 9:08 PM
You need LynDoor™Press' latest release, "101 Ways to Make Grease from Palm Colonel Oil".
Re: grease making
10/14/2011 3:53 AM
thanks lyn, pls how do i find this release?
Re: grease making
10/14/2011 10:27 AM
I regret to inform you that the wildly popular, "101 Ways to Make Grease from Palm Colonel Oil"., fifth edition is currently on back-order.
We'll call you when we get the next edition in the warehouse. Don't call us.
This is all a joke.
Good Answers: 146
Re: Making Grease from Palm Kernel Oil
10/13/2011 10:56 PM
Commercially, hydrogenation would do it.
At home, try processing in a blender with a drop or two of water.
incus opella
10/14/2011 3:39 AM
can u elaborate pls..
Good Answers: 146
10/14/2011 10:19 AM
en.wikipedia.org/wiki/Hydrogenation is not a process that you can do at home.
A semi-solid such as palm oil may be made sufficiently solid to use as a 'grease' by aerating it in a blender. If the consistency isn't adequate - warm temperature will cause it to melt back to liquid state in any case - then adding a small amount of water (or other non-oily liquid) and processing in the blender will help you to obtain a solid consistency. The tendency of the product made with water to become rancid, means it must be stored in a refrigerator and used within the expected time period of its shelf life.
That should be enough information for you to experiment.
incus opella
Good Answers: 59
10/14/2011 12:06 AM
Palm oil is an organic mixture of various components. Many of which will go rancid, lose lubricating capability or harden. It takes a bit of chemistry to stabilize it for long term use. For short term, you can use as is, and I believe it is not a contaminant to food. But check that one out, if is permitted at your place.
Industrial grease? yeah, maybe. But it takes more chemistry, than the question indicates available.
Palm oil can be used as biodiesel, as a strictly limited shelflife item.
10/14/2011 6:13 AM
i want to expperiment dis but i need details
Good Answers: 123
10/19/2011 2:20 PM
Take a large quantity of palm kernel oil to the local chain style auto parts store, and do your best to convince the kid with the pimples that palm kernel oil will cure his acne. Then barter.
Bob
Register to Reply 9 comments
artsmith (2); bob c (1); leveles (1); lyn (2); mark2sunny (3)
