I had recently placed some clear PE masking tape through a UV curing lamp where usually being used for curing UV ink. The UV treated masking tapes were being used to paste over a few pieces of perfectly good PMMA and PC sheet for protection. After a lapse of 8 hrs the masking tape were removed and I found the surface of the PMMA sheet had crazing marks all over it surface! Whereas on the PC sheets there was none, could anyone able to explain what has actually happened to cause this crazing only PMMA sheet? Thank you.
