Assuming this is most likely a heating system you need to turn up the water temp to its max setting, and then turn the pump off; after it has got to the highest temp, and then bleed the air out. Water contains disolved gasses that will be released faster when the water is heated. The reason for turning off the pump before bleeding off the air is so as not recirculate the air back into the lower part of the system. If you have a contiuing problem then you may well have a leak. This does not mean you will have vissible water but when the system cools down particularly in the cold of winter the system can draw in air from a joint or compression fitting as a partial vacuum is formed due to the water shrinking in volume as is cools down. Air is easily sucked in but water may not show. Check all joints and if radiators are in use their bleed valves.
We call them air separators, but I like the term swirl pot -- a bit more descriptive.
We have had luck in modifying the pipe where it makes a turn from horizontal to downward by Teeing the line with a length of pipe upward and putting an automatic vent on the upward dead ended Tee, it does a good job of trapping air to get rid of it.
Depending on factors such as everything. System application, open or closed loop, operating temp., supply and return pressures, fresh or brine or glycol based or even DI or RO....etc...
Your application could lend itself to draw a vacuum on the resevour. This would serve to 'out-gas' the water; Or, add a column too high that vacuum could draw up the water to the vacuum pump. This would work if the system is closed loop and has some type of sealable resevoir with a void space above the water line.
Or if it is the oxygen in the air you want out and leave the rest......Buy a fish! lol
If life is like a box of chocolates, why do I get the coffee one? That sucks!
Sorry folks;
I missed a "not" between could & draw. 4th last sentence.
Keep in mind the height of the column would be served on ambient pressure loops.
