Previous in Forum: Sodium Petroleum Sulphonate   Next in Forum: chemical engineering process design and simulation
Gas Bottle
10/14/2011 4:57 PM
Hi there, does anyone know the volume and pressure in these disposable CO2 bottles?
Sorry for the size, tried to drag the corners, but did not work
Re: Gas Bottle
10/14/2011 5:17 PM
Re: Gas Bottle
10/14/2011 5:18 PM
At first I thought the middle one the be a 12 gram Powerlet. But, I see your examples are threaded so that isn't it.
Sizes? Scale?
[edit] It looks like lyn knows what they are.
Popular Science - Weaponology - New Member Canada - Member -
Location: In the sticks of the Central Kootenays, BC, Canada
Re: Gas Bottle
10/14/2011 10:32 PM
It seems to me that liquified CO2, which is what will be in those disposable bottles, is about 900 psi at room temperature. Of course, the pressure will vary with the temperature of the CO2.
Jon.
Re: Gas Bottle
10/15/2011 1:54 AM
Pressure in CO2 bottles should be the same for all bottles at the same % fill. As for the volume jut fill it with H2O from a large syringe and see how much it holds. If you cant find a syringe with volume markings mark where the plunger is before you fill the cartridge and then refill out of a graduated cylinder.
Working to end the use of carbon for energy
Re: Gas Bottle
10/15/2011 4:22 AM
I think you meant AT the same Temperature and with partial full (that is liquid and vapor in the bottle).
Re: Gas Bottle
10/15/2011 9:53 PM
Pressure at room temp is aprox 853 deg C.
Check this link,
http://www.warpig.com/paintball/technical/gasses/co2dynamics.shtml#2
Register to Reply 6 comments
Doorman (1); garth (1); LAA_Lucke (1); lyn (1); regsoft (1); sawmilleng (1)
