Hello,
I'm having some problems with some thermocouples and hope someone can provide some assistance...
I have attached a few crude pictures for reference.
Type K Grounded thermocouples (SERP-K-1, Omega Engineering) are connected to a machine.
There are 20 thermocouples in the system.
The thermocouple leads are connected to a data acquisition system (OMB-DAQ-2416, Omega Engineering) with differential inputs.
Thermocouple A is not grounded to the machine.
Thermocouple B is grounded to the machine.
The machine is a food extruder, with a 28kW DC motor, which is grounded.
The data acquisition system is connected, through a usb port, to a computer which is also grounded.
At room temperature with the power off, both thermocouple A and B read correct values (~24C).
When the power is supplied and the motor is turned on, thermocouple B temperature increases 5 to 25 degrees.
Once the motor and power are turned off the thermocouple readings return to normal.
Thermocouple A reads correct values and is unaffected by power and motor being turned on and off.
Thermocouple B appears to be picking up voltage from the extruder drive motor when power is supplied.
Since the thermocouples output in mV, picking up any voltage from the ground is significantly effecting the temperature readings.
Do I need to establish a common ground between the extruder and the data acquisition system?
Is anyone familiar with "guarding" and can this technique be applied?
Here is a link: http://www.sensorland.com/HowPage078.html
I don't think I can filter the thermocouple leads with an RC filter due to the step response, but I am not sure.
I realize that the thermocouples should probably be ungrounded type K thermocouples due to the presence of the DC motor, but this is what I have to use. Also they worked with an older data acquisition system. More thermocouples were added so a daq system with more channels was needed.
Does anyone have any suggestions? Any information would be greatly appreciated, thanks.
