Previous in Forum: Simple Connecting Series LEDs to Parallel   Next in Forum: Thermocouple/Ground Problems
16 comments
Penstock Pressure
10/18/2011 4:37 PM
How we can calculate the pressure of water in penstock at any Hydro power plant? Any real time example of penstock pressure calculation?
Re: Penstock Pressure
10/18/2011 4:46 PM
Psi = (head in feet)/2.31
10/18/2011 7:23 PM
Is this true in the southern hemisphere, as well?
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
10/18/2011 7:52 PM
We use the special LynDoor inverse manometer which prevents the fluid from falling out.
10/18/2011 8:32 PM
Thanks for the shameless plug.
LynDoor™Industries is going to send air lift a special gift to you for the unsolicited endorsement of one of our premier products, with sales of over five units last year.
They are on back-order now. Oh the smell of success!!!!!
We'll send it by air. Let us know when if you get it.
10/19/2011 12:16 AM
Yes, with a minus sign.
This means that we can let water flow downhill in the Northern Hemisphere, and pipe it horizontally to the Southern. There the water flows uphill, and can be piped horizontally back to the Northern Hemisphere. Energy is extracted both up and down, minus frictional piping losses. I'm surprised DaS Energy hasn't mentioned this yet.
10/19/2011 5:29 AM
what's about 2.31..??
2.31 is value of which factor..??
10/19/2011 8:09 AM
10/19/2011 1:48 PM
How about this: 1 foot of regular water will exert 0.43197 PSI on whatever is below it.
You might need a slight correction factor if there are fish swimming in it.
Is this homework, I hope.
Location: OZ, otherwise known as Oklahoma were the wind comes sweeping down the plains.
Re: Pen-stock Pressure
10/19/2011 2:33 PM
1 PSI equals 2.31 Feet of water column, or 2.31 Feet of water column equals 1 PSI. This for a static column of water, with flow in your penstock there will be friction losses that will reduce the PSI by some amount.
Good Answers: 19
10/20/2011 12:06 PM
Only during static conditions. If there is a flow in the penstock, frictional losses might be a factor to reduce the available pressure. If water is moving at a significant velocity, friction loss is a subtraction from the static pressure.
Good Answers: 70
10/18/2011 11:24 PM
Why does this smell like a home work assignment? And, how does the Coriolis Effect play into the equation? Or, is this only true when you factor in the Blonde variable?
Good Answers: 59
10/19/2011 12:33 AM
You are quite correct in asking these refined questions. But, you must realize, these are masters /Phd level subiects, not to be touched by simple undergraduates.
Real life, sir - is not as simple - as you prefer to imagine, if you allow my importunity.
Good Answers: 70
10/19/2011 10:40 PM
I guess you just don't get, do you?
Good Answers: 804
10/19/2011 9:38 PM
All I want to know now is how we figure in the "factor of 11" into this...
10/19/2011 9:57 PM
And how about the other factors, 3 and 7? Spooky, huh?
10/20/2011 4:17 AM
Pressure of any liquid anywhere is its density multiplied by its depth multiplied by the acceleration due to gravity.
Register to Reply 16 comments
AussieBob (1); dj95401 (2); Grand Poobah (1); JRaef (1); kkhaliod (1); leveles (1); lyn (3); Mikerho (1); PWSlack (1); Ried (1); Tornado (3)
