Previous in Forum: Landscaping in Compacted Soil   Next in Forum: What @#$% means in slang writing
25 comments
Coriolis Effect
09/07/2011 1:11 PM
Hi,
I would like comments on the subject of coriolis. I know the subject has been debated in this forum before but I couldn't find any reference to the aspects I am concerned about.
I maintain that coriolis effect cannot occur on a body moving East/West over the surface of the earth. Text books and many very knowledgeable people disagree. I also maintain that the effect is independent of the body's mass. This, again is not what many authorities say.
To illustrate the E/W question, I have set up an example which I think illustrates my point.
If we establish some approximations it will simplify things. Let us assume that the apparent surface speed of the earth at the equator is 1000 nautical miles per hour. At the poles it is zero and at 59 deg latitude it is 500 nmph. The length of a degree of longitude at 59 deg latitude is 31.034 nautical miles. and at 61 deg is 29.215 miles. That means that there is a 6% difference between the length of a degree of longitude at 59 deg lat and one at 61 deg. Therefore there is a difference of 6% in the apparent surface speed of the earth between those two parallels of latitude which are 120 miles apart.(60 nautical miles per degree of latitude). Let us ignore both friction and centrifugal force.
If we take a theoretical parcel of air set in motion to travel true north, from any point on latitude 59, at 10 knots (nautical miles per hour). It will reach latitude 61 12 hours later. In that 12 hours it has also travelled 6000 miles in an Easterly direction due to Newton's first law of motion. However, the earth at latitude 61 has travelled 6% less than that or 5640 miles. This difference has caused an apparent curvature to the right and is what I understand as the coriolis effect.
If a similar parcel of air is set off in an Easterly or Westerly direction, from any latitude but the equator, it will take a great circle route and eventually will begin crossing lines of latitude and exhibit coriolis effect. However, in the short distance of 120 miles, it will not change much latitude and the amount of coriolis effect it shows will be minute.
This illustrates, to me, that coriolis is not shown by bodies travelling E or W and that the degree of coriolis shown by a body is dependent on the angle at which the body is crossing parallels of latitude (and on the absolute latitude).
And the effect is quite independent of mass. In this case the mass of the parcel of air. But it could be a missile or an artillery shell. A missile will show coriolis according to it's speed, it's direction,and it's latitude but it's mass will have no influence (again ignoring friction and centrigugal force).
I know there is a lot of woolly thinking regarding coriolis. But I can also see that a lot of you are capable of some serious thought.
So please tell me your thoughts on E/W coriolis effect and on the influence of mass.
BTW coriolis gets very interesting when you think of it in the context of a space craft which is rotating to create artificial gravity and two people tossing a ball to each other inside it.
Mike.
Good Answers: 183
Re: Coriolis effect
09/07/2011 2:11 PM
The acceleration is the time derivative of a velocity vector. A vector has 2 elements : its module which means its magnitude and its direction. If the direction is changed over time even if its module is not this can be done only with a force implying an acceleration in the direction's change. This is the Coriolis acceleration. Its magnitude is proportional to the product of two values: the vector magnitude and the rate of angular direction change. Its direction is perpendicular to the vector's direction and has the sens of the angular change. If there is no movement perpendicular to the rotation vector in radial direction then there is no Coriolis acceleration and no Coriolis effect.
We are in general accustomed to accelerations due to the vector module changes and less to its angular position.
Re: Coriolis effect
09/07/2011 6:03 PM
This would explain why the Blonde's in Los Angeles, California are more dizzy and spun-out than the Blondie's in Seattle, Washington!! It seems like the California Valley girl's suffer more from the Coriolis Effect than their Northern counter-parts
Good Answers: 70
Re: Coriolis effect
03/23/2012 3:41 PM
Here's my proof and I'll rest my case
Good Answers: 130
Re: Coriolis effect
09/07/2011 6:49 PM
Coriolis is caused by the angular differences in the axis of earth and the tangential plane your air mass is 'level' with. I.e. at the equator the axis are perpendicular, so the peripheral velocities are uninfluenced.
As your plane moves toward the poles, the angular differences in the axes becomes greater, so does the velocity differential across the plane - as you observed - with the velocity verses latitude.
I.e it is a matter of tilt of the gravity plane off-parallel with the axis of Earths rotation.
As to why the effect is not 'totally nuts' in the arctic; there are many other drag and thermal (density) effects in play, that counteract surface flow, such as the opposite upper atmosphere polar circulation, warm, or cold, ocean surface currents and physical barriers, such as mountains, interfering with the energies.
So - if you think of it more like a set of tops set spinning at each line of latitude and look at their tilt compared to earths axis, you may see that which way the top is moving, in the sense of east - west has little impact, as the tilt is unchanged.
Good Answers: 67
Re: Coriolis effect
09/08/2011 6:08 AM
GA. This effect is due to Earth's rotation in it's axis. Whether orbitting speed of earth cause such effect for space flights? Earth is travelling around the Sun at a speed over 100000 km/hour.
Re: Coriolis Effect
09/08/2011 6:02 AM
You can't ignore centrifugal force. As an object moves east, it moves faster than the rotation of the earth and gets pulled toward the equator by the force component in the horizontal plane and is deflected to the right. Likewise, if it moves west, it is moving slower and is again deflected to the right. When it moves north, it moves where the earth is moving slower and is deflected to the right. Moving south, it moves to where the earth is moving faster, and is again deflected to the right.
If coriolis did not have an effect on east/west motion, I expect that hurricanes would look a lot different.
Good Answers: 109
Re: Coriolis Effect
09/08/2011 11:37 AM
In the Coriolis acceleration there is no force term: ac = - 2 (v x ωEarth),
v is the velocity vector, ω the Earths rotational vector.
If you think about Force then Fc = m * ac
If there is an east velocity vE then ac has a component ach in the horizontal plane and another component that is vertical.
If you split ωEarth into a horizontal (pointing north) and a vertical component then there will be a horizontal acceleration from the vertical component of ωEarth or ach = - 2 vE * ωEarth * sinφ , with φ the local latitude.
If you make a sketch of your local plane and the velocity and rotation vectors, this may be easier to get insights.
RHABE
Good Answers: 27
Re: Coriolis Effect
09/08/2011 11:40 AM
I've thought of or seen its effect every time I flushed the toilet while still living by the equator!
vsar
Good Answers: 204
Re: Coriolis Effect
09/09/2011 8:27 AM
it shows up more in the draining of the bathtub or sink... because toilets (here) have directional jets that cause the water to flow in a specific direction.
but thanks for reminding me.
chris
Re: Coriolis Effect
09/08/2011 1:30 PM
I have a serious question related to these. I took these vids while in Ecuador
The first is with the basin placed directly exactly on the equator:
"http://www.youtube.com/v/9KGYiOy8Hmc?version=3&hl=en_US&rel=0"
This was with the basin located approximately 3 feet to one side of the equator:
"http://www.youtube.com/v/-r8sHnpAqkY?version=3&hl=en_US&rel=0"
This was with the basin located approximately 3 feet to the other side of the equator:
"http://www.youtube.com/v/65aCE8MYjZU?version=3&hl=en_US&rel=0"
It all looked legit to me while standing there, but have been told that it is merely a trick that is performed for tourists ?
if it is a trick, how is it done ? and could i repeat it in my back yard in Maryland ?
thanks
Re: Coriolis Effect
09/08/2011 2:01 PM
The amount of rotation in the water is amplified by the whirlpool vortex. It would be easy to impart a little motion pulling your hand out to start the water in motion. The Coriolis acceleration is far too weak to affect the water in a basin for the short distance it moves. It would be very difficult to make a basin symmetrical enough to observe this phenomenon at higher latitudes, much less a few feet from the equator where the effect drops to zero.
Re: Coriolis Effect
09/08/2011 2:34 PM
Thank you to those who commented. Most of them reinforced my opinion that there is a lot of woolly thinking around the subject.
The toilet and other water draining examples have been thrashed to death. Probably the most interesting reply was from the person who compared blond dizziness at different latitudes.
A couple of respondents spoke of acceleration. Apart from the fact that the parcel of air must follow the curvature of the earth (less than 20,00feet in120 miles and therefore insignificant at 10 knots), there is no acceleration. The parcel is obeying Newton's first law. The coriolis effect is just that - an effect - an apparent curving to the left or right to an observer on the ground. It is not a real curve in the body's motion and therefore not an acceleration.
One spoke of spinning tops. A top is a gyroscope and follows the laws that govern gyroscopes. They are not affected by coriolis and do not illustrate coriolis.
The classic illustration of coriolis is the ball on a turntable shown here -
http://en.wikipedia.org/wiki/Coriolis_effect
but unfortunately it is only 2 dimensional so does not attempt to show the E/W effect. However it would show that mass has no bearing on coriolis if two balls of different mass were used.
I would still like to hear from someone who really understands the subject.
Mike.
Good Answers: 130
Re: Coriolis Effect
09/08/2011 2:54 PM
"One spoke of spinning tops. A top is a gyroscope and follows the laws that govern gyroscopes. They are not affected by coriolis and do not illustrate coriolis."
So is a turntable
Re: Coriolis Effect
09/08/2011 3:13 PM
Actually, the acceleration is a relative acceleration. The effect is the rate of change of velocity of an object relative to an observer. That does not mean there is no acceleration....you have to specify which reference frame you are talking about.
Viewing from an inertial reference frame the object may not be experience a change in velocity, but it is from the point of view of the observer in the non-inertial reference frame.
J B
Good Answers: 183
Re: Coriolis Effect
09/09/2011 9:53 AM
I would sincerely advise to review the basics of physics. May be after you did it you will better understand what is an acceleration and what the Coriolis effect is. you say that mass is not involved but every stuff has a mass air too. According to basic law a body which ever its dimensions are and its specific weight as long as it is material will not change its trajectory as long as a force or moment will not act upon. But as you may know a force acting on a mass generates an acceleration which has a magnitude F/M and the acting vector direction. Try to explain why the winds on the 2 sides of the equator have the directions they have.
Re: Coriolis Effect
09/09/2011 2:43 PM
The parcel of air was obeying Newtons first law. There was no acceleration because there was no force acting on it.
If you look at the example in Wikipedia showing the classic illustration of coriolis, you will see that the ball travels in a straight line. No F and therefore no A. It only appears to curve to an observer riding on the perimeter of the turntable. And the mass of the ball is immaterial (In spite of a statement on the same Wikipedia site).
Good Answers: 183
Re: Coriolis Effect
09/10/2011 5:49 AM
What you did not understand is the meaning of time derivative of a vector. Try first to understand it and then think that an acceleration is the time derivative of a velocity vector. When you are so far you will understand the Coriolis effect. As I wrote you think well but with not sufficient basic knowledge and as you know a good logical analysis started from a wrong basis leads to wrong results. Wikipedia is NOT the only possible source for information.
Good Answers: 130
Re: Coriolis Effect
09/10/2011 8:24 AM
"The parcel of air was obeying Newtons first law. There was no acceleration because there was no force acting on it."
Then it didn't move - or it continued in a straight line. But not so ... it was "rotating" ...???
It seems you are quite determined Not To Get This and Not To Be Told How To Get This.
So be it.
Carry on Nick & best of luck
Re: Coriolis Effect
09/10/2011 11:56 AM
OK I agree that Wiipedia is not the only source of information and, in fact, there are two glaring mistakes in the article we have been discussing.
But, to paraphrase Scotty, you cannot change the laws of physics.
The ball on the turntable obeys Newton's first law and, so, continues in a straight line as can be seen by an observer off the turntable. However to an observer on the perimeter of the turntable, it appears to curve. And that apparent curving is the coriolis effect. No F and therefore no A. M is immaterial. These facts can be easily observed on all sorts of rotating platforms.
Similarly with our theoretical parcel of air, it only appears to curve to an observer on the ground.
Of course, if the parcel of air is moving towards an area of low pressure, there will be air approaching from all directions and various different forces will take over. It is possible that it will develop into a revolving storm. If it does, it will be the coriolis effect (not force), that determines the direction of rotation and that depends on which hemisphere the system develops in.
Good Answers: 183
Re: Coriolis Effect
09/10/2011 1:01 PM
I am sorry to insist that without a force no particle will change its trajectory. THIS is base of the base in mechanics. Thus my recommendation to review the basics. You did not give an explanation for the winds directions yet. I still expect it.
Re: Coriolis Effect
09/10/2011 1:53 PM
Nick, first remember the parcel of air traveling North in the Northern hemisphere. To an observer on the ground the parcel appears to curve to the right. If he is in that parcel of air, he will experience a very real wind.
Now, imagine that the movement in a N direction is caused by an area of low pressure.
If the system develops over the ocean, there will probably be air approaching that low pressure from all directions. Except for the air approaching from due E or W all that air will exhibit coriolis to a greater or lesser degree The amount will depend on how far from E or W it's direction is and on the latitude of the system.
If the low pressure is maintained (eg by convection), air will continue to try to fill it and because of coriolis, will always curve to the right in the N hemispere. This will result in an anti clockwise motion around the low pressure. Of course many other effects and forces will come into play but it is coriolis that determines the direction of the wind. Which, to answer your question, will come from your left side if you face the area of low pressure.
Or, if you are standing on the perimeter of the Wikipedia turntable when the ball reaches the edge, the ball will hit you on the front of your legs if you are facing the direction of rotation. Of course, the exact angle it hits you at will depend on the speed of rotation and the speed the ball has been given.
Good Answers: 130
Re: Coriolis Effect
09/10/2011 7:13 PM
Good Answers: 183
Re: Coriolis Effect
09/11/2011 5:43 AM
You make progress ! This is good ! What makes the air particle move normal to its original path S-N or N-S ? You say "Coriolis" which is correct but no mass will change its trajectory without a force acting upon and as you know Force /Mass = ACCELERATION.
Thus the mention of Coriolis acceleration in my 1st mail which you considered as wrong.
Same logic you use for the wind is valid for the water flowing to the sink.
Coriolis acceleration is proportional to the RADIAL component of velocity x angular rate.
Let us look at the ball on the rotating plate. The initial velocity is radial so that on the ball will act a force which is proportional to the radial velocity magnitude x angular rate. This force is (if friction is neglected) constant as long as the conditions are maintained (i.e. velocity and angular rate). The ball will have a parabolic path since tangential acceleration is constant and radial velocity as well. This is valid on the relative reference system of the plate. With respect to an observer outside of the plate (absolute reference system) this movement will be combined with a transport tangential movement which is governed by the product radius x angular rate. The radius increases with the radial velocity (initial value) x time. Now I let you make the equations and define the path. For none of the observers the path stays linear.
In such cases it is of interest to split the system for its analysis in relative and transport motions it makes understanding easier.
Re: Coriolis Effect
09/11/2011 12:22 PM
Nick, let's invoke the KISS principle and concentrate on the turntable and ball. And, as you say, ignore friction.
If the turntable is stationary, the ball will obey Newtons first law and move in a straight line until it reaches the edge. This can be seen by both an observer on the turntable and by an observer off the turntable and they will see no sign of coriolis because there isn't any.
Now, the ball does not care if the turntable is rotating or not. And nor would Sir Isaac Newton. The ball will follow his first law regardless of whether the surface beneath it is moving or not.
However, if the table is turning, the ball will describe a curved path and so show the coriolis effect to an observer on the perimeter of the table.
But, no matter how fast or slow the turntable is rotating, no matter how fast or slow the ball is moving and no matter what the mass of the ball is, it will be seen to take a straight line to an observer off the turntable.
Try it yourself and let me know what you observe.
Good Answers: 183
Re: Coriolis Effect
09/11/2011 3:45 PM
Due to the lack of friction when the table turns the ball is NOT in rotation with respect to the axis so that its speed is NOT influenced in its direction by the rotation. I wanted to see if any body will react at that but unfortunately gain the basics are not present.
The Coriolis effect appears ONLY if the body which has a velocity in radial direction is moved in a rotation around an axis.
One MUST have the speed direction change to obtain a Coriolis effect. If for instance you would have a groove on the table and the ball moves along it in radial direction it will be pushed against a wall or the other as function of its speed and of the angular rate. This an effect noticed in streams flowing from N to S: the two sides are not the same since one is more eroded than the other.
Register to Reply 25 comments
34point5 (4); Anonymous Poster (1); chrisg288 (1); dj95401 (1); JBTardis (1); nick name (6); Oraka (5); pritam (1); reefdiver (1); RHABE (1); Rixter (2); vsar (1)
