Previous in Forum: Warehouse   Next in Forum: Difference Between Valve Hunting & Chattering?
Hyrdrotest of Heat Exchanger
10/20/2011 7:22 AM
Dear all,
For those who has any experienced;
I would like to conduct a hydrotest,
- fill up a water at shell side and then pressurized up to 25 barg
- to heat up until 200 DC from the shell side.
If anyone has a method on how to do that, please let me know.
Thank you
Re: hyrdrotest of heat exchanger
10/20/2011 7:29 AM
I take you are building it to ASME Requirements and do not have the ASME references
10/20/2011 7:33 AM
ASME does not call for hydro test at 200 deg C. Well, what is your MDMT?
RK
Re: Hyrdrotest of Heat Exchanger
10/21/2011 4:27 AM
Follow the guidance given by the Engineer/Surveyor from the company that will be supplying burst indemnity insurance cover for the vessel.
To the letter.
10/21/2011 7:42 AM
If they don't have it, then expect to be dropped or at the minimum and a large increase in its premiums
10/25/2011 2:48 AM
You are asking experience without any code reference. The hydro test you are conducting is for your ref. or for acdemic reasons or homework.
brkmech (1); Mukesh0861 (1); phoenix911 (2); PWSlack (1)
