Previous in Forum: Difference Between Valve Hunting & Chattering?   Next in Forum: How to Calculate External Pressure of the Internal Tank
India - Member - Proud to be INDIAN Engineering Fields - Power Engineering - New Member
Rated Torque and Peak Torque
10/21/2011 6:06 AM
What is the difference between Rated Torque and Peak Torque with reference to specification of a torque motor???
Please elaborate, Thanks in advance
Sharath
you need to go, to get something
Re: Rated Torque and Peak Torque
10/22/2011 2:20 PM
Dear Mr.Sharath4,
Rated Torque is the Torque calculated at the rated power out put or at the DESIGN VALUE. Peak Torque is the maximum torque developed by the same equipment while working. Peak Torque may be above the rated torque or below the rated torque.
dhayanandhan.s
10/23/2011 11:53 PM
Dear sir,
Thanks for reply
I found that in almost all torque motors, the peak torque is more than the rated torque only, and how to calculate peak torque?
Sharath
Good Answers: 137
11/04/2011 1:03 PM
You don't calculate it, it's given by the motor manufacturer, usually in the form of a graph of torque vs speed.
Also ref #1, I don't think peak torque can be below the rated torque, or it wouldn't the peak torque.
11/06/2011 4:01 AM
so i want to become motor manufacturer, i also know that peak torque value will be given by the manufacturer, but how did they arrive that value,, i want that...
That's why i am asking.
I also agree that peak torque cannot be less than the rated torque.
Good Answers: 137
11/06/2011 1:25 PM
They would carry out tests. I'm not sure how it's done. Torque at zero speed (locked-rotor torque) is straightforward. At other speeds, I suppose the motor could be loaded via a dynamometer to keep the speed at say 10% of synchronous, and measure the torque, then repeat for a range of speeds.
Maybe somebody out there has more details.
10/22/2011 9:26 PM
10/23/2011 11:54 PM
Thanks but i didn't got answer to my question
Register to Reply 7 comments
Codemaster (2); dhayanandhan (1); lyn (1); sharath4 (3)
