Previous in Forum: Amateur Hovercraft Build   Next in Forum: Generator
10 comments
Mini Project - Maintenance Based on Vibration Measurement & Analysis
10/21/2011 6:37 PM
Helloi have already choose a topic for a mini-project somehow it's a self-learning training by a new professor about ((Maintenance Based on vibration measurement and analys). it's not a big deal , i just want the right formal and official way and method to do well what he asked for to get those marks :)he asked me to do that:
Short introduction before November 1st
Draft presentation December 1st
Final project presentation December 15
please help before i'm done :S
thanks
Good Answers: 70
Re: Can i ask for help in that ;) ?
10/21/2011 6:58 PM
First, you need to give us some kind of idea what your mini-project is, or is this the self learning portion of the project?
10/21/2011 7:09 PM
hummm , i hope i got what you mean
it's a research about the topic i mention it
10/21/2011 7:16 PM
So what research have you done? I dare say there may be a couple of folk here who'd give you a hand to knock your draft papers into shape, but it ain't a free ride - no-one's going to do the research for you.
Do some work, come back with some results, and we'll see.
P.S. Make sure to keep a note of all your references.
10/21/2011 7:19 PM
i afraid you didn't understand me
i need the frame , how to write it ... i already done with the info needed
10/21/2011 7:19 PM
I'd get started, if I were you because if you think anybody here will do your homework for you, I think you are mistaken.
The reason the instructor gave the assignment to you is because he wants you to do the work. Otherwise, he just would have given you this web address and told you to cut and paste.
So, I'd get on with it.
10/21/2011 7:23 PM
wow , why nobody can't understand what i need a hand in ?
i don't want you to give me the research ..... just the formal way and i will adjust my info ( that i already got ) , to do the right draft , report
10/21/2011 7:29 PM
So you expect us to dream up some ficticious project, pretend we've done a load of research and written up our notes, then lay them out in phases 1), 2) and 3), so you can copy the style?
Your college library must be full of similar reports - do some research in that area.
10/21/2011 7:47 PM
I just googled "how to prepare a p-----t r----t".
Your first self learning task will be to fill in the blanks above.
Do your own homework.
Good Answers: 70
10/21/2011 7:30 PM
OK, how about this, Try researching failure rates due to vibrations. Then, base your maintenance on what you learned in your research. Everything has different failure rates, that's why there's different maintenance programs related to the type of equipment, etc.
Re: Mini Project - Maintenance Based on Vibration Measurement & Analysis
10/24/2011 2:41 PM
Have you tried an internet search of "formal report"?
Formal report writing is generally taught (or at least basics provided) as part of the course, but again not all of them (which appears to be the case here). Do you have any report writing experience from school, it may not have been engineering-based but will follow similar principles?
There are quite a few methods to report writing and presentation, but generally you start by introducing your topic, briefly explaining what it is and why you did it, presenting your results and tying the whole thing together with your conclusion and end result. Keep it fairly formal, don't use TxT language or slang, don't use 20 words to say what 4 words could (ie- don't pad out your report), and for presentations, watch your time (don't make it too short or too long).
An internet search for "formal report", etc should give you more idea.
Register to Reply 10 comments
dj95401 (2); jack of all trades (1); JohnDG (2); lyn (2); Yasser Azmy (3)
