Previous in Forum: Reliable Solenoid Testers   Next in Forum: Modifying the Dimmer Circuit
11 comments
Power Cables Ampacity
10/23/2011 11:48 AM
is there any formula /table giving the ampacity of power cables according to cable area e.g for a rat 3.phase load of 50A ,what mm2 cable should we use for safe operation. in short ,what is the relationship between power cable size (dia/area) and its ampacity. reference to any useful literature will be appreciated.
Re: Power cables ampacity
10/23/2011 11:56 AM
Quit being so flippin' LAZY.
If you are so totally helpless that you can't do your own work, then you should quit asking us to do it for you.
Most of your posts are questions any first year electrician should know. Grow up.
There are literally dozens of charts on the web, and if you weren't so flippin' LAZY you could find them for yourself. Why don't you find some other forum for lazy people and bug them.
Wire Sizing Charts
10/23/2011 12:06 PM
Good f.....g grief! Get a copy of your local electrical code.
10/23/2011 12:52 PM
The American Wire Gauge numbering system gives the current rating directly. For example, 10 AWG will carry 10A, 22 AWG will carry 22A etc.
If you intend to trust what you read in an open forum of anonymous members to design your "safe" system, you may as well use my "rule of thumb". It will be particularly "safe" for the higher current/AWG pairings.
10/23/2011 1:01 PM
You may be confusing that with fast-acting fuse design, especially in the upper ranges.
10/23/2011 1:06 PM
Quite. But it's very safe (unless holding the wire when power is applied, or working in an explosive atmosphere ).
10/23/2011 1:11 PM
Or a fusible link? Wink, wink.
Good Answers: 181
10/23/2011 1:31 PM
If some was to give you a link to the information you want:
A/ would you take the time to read it?
B/ would you understand it if you read it?
You are just taking up space in your position (if you have one), you have nothing to add to any work place!
10/23/2011 2:29 PM
I agree with "Lyn" and "Tornado"..My suggestion is that your boss should fire you a**s and get someone with at least 2 brain cells. It seams if you have none!!!!
10/23/2011 2:33 PM
Looking for a Formula. Check this out.
By definition, No. 36 AWG is 0.0050 inches in diameter, and No. 0000 is 0.4600 inches in diameter. The ratio of these diameters is 92, and there are 40 gauge sizes from No. 36 to No. 0000, or 39 steps. Using this common ratio, wire gauge sizes vary geometrically according to the following formula: The diameter of a No. n AWG wire is
or equivalently
The gauge can be calculated from the diameter using
and the cross-section area is
The ASTM B 258-02 standard defines the ratio between successive sizes to be the 39th root of 92, or approximately 1.1229322. ASTM B 258-02 also dictates that wire diameters should be tabulated with no more than 4 significant figures, with a resolution of no more than 0.0001 inches (0.1 mils) for wires larger than No. 44 AWG, and 0.00001 inches (0.01 mils) for wires No. 45 AWG and smaller.
Sizes with multiple zeros are successively larger than No. 0 and can be denoted using "number of zeros/0", for example 4/0 for 0000. For an m/0 AWG wire, use n = −(m−1) = 1−m in the above formulas. For instance, for No. 0000 or 4/0, use n = −3.
Good Answers: 130
10/24/2011 8:34 PM
Wow!
So much simpler than 10 A/mm2 for copper.
Re: Power Cables Ampacity
10/24/2011 6:47 AM
British Standard 7671. Again, and again and again....
Register to Reply 11 comments
34point5 (1); JohnDG (2); lyn (2); PWSlack (1); TonyS (1); Tornado (2); VLF (1); wareagle (1)
