Previous in Forum: Transformer Vector Group   Next in Forum: Working with Electricity
Hi Pot Test
10/24/2011 11:01 AM
What is the best possible way to determine the voltage level to be applied for a 20KV power cable during Hi Pot test?
Cable Desription
12KV/20KV
Re: Hi Pot Test
10/24/2011 11:02 AM
Look it up in the manufacturer's tables that were used to select the cable in the first place.
Re: Hi Pot Test
10/24/2011 12:33 PM
Re: Hi Pot Test
10/24/2011 12:42 PM
Check Okonite Cable here
Re: Hi Pot Test
10/24/2011 3:32 PM
No, no, no. You're supposed to take six rolls of an eight sided die and multiply all six values together. This random mathematics will tell you the voltage your supposed to use in your high pot test of the cable. Then roll two ten sided dice simultaneously. If you get the same digit on both dice, this invalidates your previous rolls. Start over. This procedure will completely remove any repeatability of your results with the manufacturer, but it will keep you occupied for a fairly long time.
Thank You and Come Again.
Register to Reply 4 comments
lyn (1); PWSlack (1); redfred (1); wareagle (1)
