Previous in Forum: Sag Of Line Wires   Next in Forum: UPS Working Without Battery Indication
Failure Metal High Halide Lamp
10/31/2011 4:49 AM
i have big problem in metal high halide lamp , what is the reasons for failure and burn the lamps although it did not complete the life time and i observed that the inner glass of lamp is black ( burn and charred)
Re: failure metal high halide Lamp
10/31/2011 4:58 AM
1. Voltage spike?
2. Did someone insert the lamp with bare fingers, which is a no-no?
10/31/2011 5:25 AM
Vibration?
Frequent switching on and off?
Voltage consistently too high?
Is the inner surface of the glass blackening on the lamps which have not yet failed?
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: Failure Metal High Halide Lamp
11/07/2011 10:47 AM
Be sure the correct wattage of bulb is used, as someone who had never worked with HID lamps, I tried to replace a 400W bulb with a 175W bulb, hoping to save a little money on electricity. We didn't get more than a couple of months out of that lamp. It was then I found out that the ballast on Metal-Halide lamp fixtures is designed to drive a certain wattage lamp.
Also, I believe there are lamps made for different bulb orientations, such as base-up, base-down, or universal, which can be installed in any orientation. If you install a "base-down" lamp in a "base-up" fixture, I would expect to see a decreased life expectancy on that bulb. Just some random thoughts.......
Tom D.
JohnDG (1); tdesmit (1); Tornado (1)
