Previous in Forum: Modification in DC Drive   Next in Forum: Oil Filteration of Transformer
Neutral Grounding Disconnect Switch
11/02/2011 3:24 PM
If a gen set is synchronized parallel with utility and its neutral grounding switch fail to disconnect, what are the possible risk to the generator and the one who is operating the generator ?
Good Answers: 181
Re: Neutral Grounding Disconnect Switch
11/02/2011 4:29 PM
Try looking at your last post on exactly the same question
11/03/2011 3:12 PM
I didn't understant the answer at my last post. I thought my question was not clear, that why decided to ask again. I still need your help.Before, the neutral grounding disconnect switch was working automatic. when the generator synchronized with national grid ( another source of power) it used to open and share the national grid ground and when there is no any source of power it close and make the ground. But now the switch has closed permanently whether generator runs with or without national grid( utility voltage) . Are you advise me to continue with operation ?
Register to Reply 2 comments
